69 x with a rpm performer,air filter #1378447
01/30/13 09:23 AM
01/30/13 09:23 AM
indy
70moparmike Offline OP
indy
i have a 69 gtx 440 planning on running rpm performer intake. have a air grabber set up, i know no base will fit it!! been there, will i be able to get a air clearner under the hood with this intake and leave the grabber assy in place? any pic's of set up's? thanks moparts
Re: 69 x with a rpm performer,air filter [Re: 70moparmike] #1378448
01/30/13 12:23 PM
01/30/13 12:23 PM
indy
indy
nobody used a rpm performer on a b body?
Re: 69 x with a rpm performer,air filter [Re: 70moparmike] #1378449
01/30/13 12:28 PM
01/30/13 12:28 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I seriously doubt it.. And I have a Performer RPM going on my 68 Coronet R/T... Without the Airgrabber I'll be using a 3/4" drop base...
Re: 69 x with a rpm performer,air filter [Re: 70moparmike] #1378450
01/30/13 01:02 PM
01/30/13 01:02 PM
tucson az
frank Offline
frank  Offline
tucson az
You will need to cut a base to fit your setup. There is a member here who sells what you need. It's made of fiberglass. I used it on mine and it came out OK. I'm using a SD intake with air grabber. I don't remember who the member is.
Re: 69 x with a rpm performer,air filter [Re: frank] #1378451
01/30/13 01:20 PM
01/30/13 01:20 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no it will not fit you will need a drop base or modify your factory base.
Coming soon!!!!
Re: 69 x with a rpm performer,air filter [Re: Mr.Yuck] #1378452
01/30/13 01:36 PM
01/30/13 01:36 PM
indy
indy
i'm not worried about the base, just wanted to know if the manifold will fit under the hood with a aftermarket air cleaner? rt told me that it is too tall with only an inch between the hood and top of carb? will not be enough air flow?
Re: 69 x with a rpm performer,air filter [Re: 70moparmike] #1378453
01/30/13 01:49 PM
01/30/13 01:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
An inch is not a lot of room , you'll have to run a shorter height air filter and that will restrict airflow , but you could use a KN filter top?
What carb , does it have an air horn ? if a 14" air filter will not fit inside the air seal holder a 13" should.
Re: 69 x with a rpm performer,air filter [Re: JohnRR] #1378454
01/30/13 01:53 PM
01/30/13 01:53 PM
indy
indy
trying to figure out if the manifold will work in the car somehow? surly someone on here has used the rpm performer on a gtx, rr before? if it won't fit i'll try anouther intake?
Re: 69 x with a rpm performer,air filter [Re: 70moparmike] #1378455
01/30/13 01:57 PM
01/30/13 01:57 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I have a performer rpm intake on my engine.
I modified a fibre glass air grabber base by cutting a large hole in it and fitting it to a 1 1/2" drop down base.
I just use a drop down air cleaner base these days.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: 69 x with a rpm performer,air filter [Re: Mick70RR] #1378456
01/30/13 01:57 PM
01/30/13 01:57 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
Pic.
Re: 69 x with a rpm performer,air filter [Re: 70moparmike] #1378457
01/30/13 04:57 PM
01/30/13 04:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The manifold and a carb will fit , it's the air cleaner that is the problem.
What carb are you going to use ?
Re: 69 x with a rpm performer,air filter [Re: JohnRR] #1378458
01/30/13 05:27 PM
01/30/13 05:27 PM
indy
indy
holley hp.
Re: 69 x with a rpm performer,air filter [Re: 70moparmike] #1378459
01/30/13 06:32 PM
01/30/13 06:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
holley hp.
Does it have a choke tower ? If not you should be able sneak it in there with the lowest drop base available ???
The pictures of the 70 above show it can be done ... on a 70 which has a raised center on the hood ... I don't know how much more higher that hood pokes up vs. a 69 hood ...
Re: 69 x with a rpm performer,air filter [Re: 70moparmike] #1378460
01/30/13 09:35 PM
01/30/13 09:35 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I don't have a 69 so I cannot speak from experience
If the 69 has as much room as a 67, than it can fit.
I have spent some time measuring and estimating the minimum room you need between the carb top, and the hood,....no less than 2", if everything is right. That assumes a roundy-round type air cleaner and a carb without a choke tower.
Re: 69 x with a rpm performer,air filter [Re: BSB67] #1378461
01/30/13 11:38 PM
01/30/13 11:38 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I asked the same question regarding my 70 Coronet with 440 a few weeks ago. The Eddy RPM is such a popular intake, I am surprised more don't have clear cut advise on the clearance for your vehicle. I am using a no-choke Holley 4160 and RPM. I haven't dropped my engine yet and face the same dilema, albeit, I don't have the fresh air setup.
The guy who does fiberglass bases for air grabbers is Steve, goes by the name Paint It Black. I would try to retain your air grabber if you can. If not, my birthday is in march.
I’m listening.
Re: 69 x with a rpm performer,air filter [Re: BSB67] #1378462
01/31/13 10:51 AM
01/31/13 10:51 AM
indy
indy
is that a spun aluminum air cleaner? my engine guy recomended trying one of those. i am not sure if i want to knock out the choke? it will be a street car? is that manifold a rpm? thanks
Re: 69 x with a rpm performer,air filter [Re: Big Bad Bee] #1378463
01/31/13 10:55 AM
01/31/13 10:55 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
as with any performace air cleaner you will need a DROP BASE. Even a factory 6-pack has a drop base. The RPM will fit under and flat hood but you will need to call Summit and order an air cleaner assembly. I used a 14x3 w/ a 1 3/4" drop for my old 67 coronet.
Re: 69 x with a rpm performer,air filter [Re: Mr.Yuck] #1378464
01/31/13 11:14 AM
01/31/13 11:14 AM
indy
indy
is the distance pretty close to the 69? everyone is saying that is the closest hood clearance of them all?
Re: 69 x with a rpm performer,air filter [Re: 70moparmike] #1378465
01/31/13 09:44 PM
01/31/13 09:44 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I would guess that the clearance is tighter with my 67 than your 69 w/air grabber.
Yes, spun aluminum.
440-2D intake. Same height as the RPM
