Trying to pick a cam for my 505 but how do I tell PV? #1378229
01/29/13 06:03 PM
01/29/13 06:03 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
without actually buying a cam, putting it in, putting clay on the piston, only to find out there will be PV issues, is there a way to tell before I pick the cam? I have all the specs of the build.
Thanks!
RS23L7 4-Speed
Re: Trying to pick a cam for my 505 but how do I tell PV? [Re: Mopar_Mike] #1378230
01/29/13 07:42 PM
01/29/13 07:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is the shortblock together yet ?
Re: Trying to pick a cam for my 505 but how do I tell PV? [Re: JohnRR] #1378231
01/29/13 07:48 PM
01/29/13 07:48 PM
Danville, NH
Danville, NH
yeah
RS23L7 4-Speed
Re: Trying to pick a cam for my 505 but how do I tell PV? [Re: Mopar_Mike] #1378232
01/29/13 07:51 PM
01/29/13 07:51 PM
dogdays Offline
dogdays  Offline
You need pistons, not rings, on the rods installed in the block on the crank everything bolted down but not necessarily ready to go, but you need bearings...if shortblock is already assembled that's OK too.
With valves in the head you're going to use and lightweight springs on the valves, bolt the head down and bring a piston to TDC. Then using some kind of measuring instrument, measure the distance you can push the valve down before it touches the piston. Do that for each cylinder if you want to be careful.
Now you know the maximum the valve can be open at TDC. With that information your cam grinder "should" be able to tell you if the piston-to-valve clearance will be OK with a particular cam installed on a particular center line. Of course that requires you to know where the real TDC is, but if you are going to be close, it never hurts to measure a bunch!
R.
Re: Trying to pick a cam for my 505 but how do I tell PV? [Re: dogdays] #1378233
01/29/13 07:58 PM
01/29/13 07:58 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
VALVE does not hit piston at tdc it hits after tdc,if its going to
Re: Trying to pick a cam for my 505 but how do I tell PV? [Re: CSK] #1378234
01/29/13 08:07 PM
01/29/13 08:07 PM
dogdays Offline
dogdays  Offline
If you don't know what cam you're using, you have no idea where that's going to happen. But you can find out the distance at TDC. You could even find out the distance at 10 degrees BTDC and 10 degrees ATDC so R/S ratio doesn't mess things up.
R.
Re: Trying to pick a cam for my 505 but how do I tell PV? [Re: dogdays] #1378235
01/29/13 11:31 PM
01/29/13 11:31 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
in past with every thing assembled iv rotated the engine at several points and make something to grab the rocker arm and open it by hand and feel it hit the piston then you can guess or install a indicator and know the clearance
Re: Trying to pick a cam for my 505 but how do I tell PV? [Re: Cheatham] #1378236
01/29/13 11:38 PM
01/29/13 11:38 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
On my 505 I have a 650 lift Crower solid lifter cam, 1.5 ratio rockers, flat top pistons, over .100 piston to valve clearance with the cam set straight up.
Re: Trying to pick a cam for my 505 but how do I tell PV? [Re: Mopar_Mike] #1378237
01/30/13 12:33 AM
01/30/13 12:33 AM
Thanks!
Not really, way to many variables as far as you degreeing the cam or not, piston valve relief depth, head thickness, piston deck hieght and a lot more variables I've treid installing a flat tappet cam with 268 duration at .050 on the intake lifter installed straight up(degreed )on a 108 LSA cam,(intake max lobe lift at 108 ATDC) it hit the piston at around 15 defrees after top dead center, I put a bigger duration solid roller cam in, 272 at .050 on a 108 LSA in at two degrees advanced, intake lobe at 106 degrees after top dead center and it had .060 V. to P. clearances It pays to know what you got Never ASSUME anything on motors with after market parts
Re: Trying to pick a cam for my 505 but how do I tell PV? [Re: Mopar_Mike] #1378238
01/30/13 12:55 AM
01/30/13 12:55 AM
AndyF Offline
AndyF  Offline
Measure the valve drop at TDC. Then compare it to the tappet lift at TDC provided by the cam mfg. That should get you close enough for most engines.
