Torque specs for flex plate and converter bolts #137815
10/16/08 10:16 PM
10/16/08 10:16 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Anyone know the torque specs for the flex plate and torque converter bolts. It is an 8 bolt crank
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Torque specs for flex plate and converter bolts [Re: Kam*Kuda] #137816
10/17/08 10:07 AM
10/17/08 10:07 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
anyone can help?
1654.5 Mustang
1955 Land Rover
Re: Torque specs for flex plate and converter bolts [Re: Kam*Kuda] #137817
10/17/08 10:20 AM
10/17/08 10:20 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Flywheel/flexplate bolts------------55ft.lbs
Flywheel housing to engine block bolts--50ft.lbs
Flexplate to torque converter bolts---270in.lbs
Re: Torque specs for flex plate and converter bolts [Re: Kam*Kuda] #137818
10/17/08 11:00 AM
10/17/08 11:00 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Last 8 bolt crank flange I messed with was a stroker 440 crank and it had 1/2 inch bolts IIRC, so I torqued to hemi flange specs. Torque converter will depend on 5/16 or 7/16 sizes.
Re: Torque specs for flex plate and converter bolts [Re: buildanother] #137819
10/17/08 12:02 PM
10/17/08 12:02 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
The converter bolts are 7/16ths
1654.5 Mustang
1955 Land Rover
Re: Torque specs for flex plate and converter bolts [Re: Kam*Kuda] #137820
10/17/08 03:42 PM
10/17/08 03:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For the 8-bolt flange the FSM recommends 70 ft. lbs. on the crank bolts and 65 ft. lbs. on the converter bolts but I don't think there's enough thread engagement for 65 ft. lbs. on the converter bolts, I would tighten them by feel with red Loctite.
