Tunnel Ram and Mechanical Fuel Pump Question #1378104
01/29/13 01:38 PM
01/29/13 01:38 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Can a Carter M6903 mechanical fuel pump adequately feed a tunnel ram and two Holley 1850 600s on a mild (425 hp or so) 440? I have 3/8" pickup and line from the stock tank to the carb.
Or, if the Carter M6903 isn't up to snuff, is there another mechanical fuel pump that would do the job? Any real world experiences with something like this? I don't want to run an electric pump for a variety of reasons. Thanks!
Re: Tunnel Ram and Mechanical Fuel Pump Question [Re: 67Satty] #1378105
01/29/13 02:13 PM
01/29/13 02:13 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
do you care about running a regulator? I use a clay smiths on my hemi w/crossram and it works awesome
Re: Tunnel Ram and Mechanical Fuel Pump Question [Re: prochargedhemi] #1378106
01/29/13 02:56 PM
01/29/13 02:56 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
I've heard good things about the Clay Smith mechanical pumps. Thanks. I should add that this thing is raced on 1/8 mile only.
Re: Tunnel Ram and Mechanical Fuel Pump Question [Re: 67Satty] #1378107
01/29/13 03:44 PM
01/29/13 03:44 PM
Is that pump one of the Carter race pumps with three diaframs(SP?)in it ? If so they will feed a NHRA legal 1963 550 HP M.W. motor sucking through the stock 5/16 O.D. fuel line with a 3/8 pickup in the tank Been there, done that years ago
Re: Tunnel Ram and Mechanical Fuel Pump Question [Re: Cab_Burge] #1378108
01/29/13 05:22 PM
01/29/13 05:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran a Holley mechanical on my 440 with Tram and 2 Carters.Never wanted for fuel.It now feeds my 1050 Dominator with no problems.Quit using Carters after we had like 3 bad ones in a row.My kid runs Holley on his 413 also.Same with the built 360.Rocky
Chrysler Firepower
