cage pics thru dash a body #1378023
01/29/13 02:15 AM
01/29/13 02:15 AM
pacific northwest
Stroker Scamp Online content OP
Stroker Scamp  Online Content OP
pacific northwest
looking to see how you ran your down bars thru the dash on an A body,I want to run the bars up front as tight as I can to the pillars
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: cage pics thru dash a body [Re: Stroker Scamp] #1378024
01/29/13 02:20 AM
01/29/13 02:20 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been thinking the same thing since my dash is gutted and chopped to hell now and I`m thinking about removing the ft. corner in line w/the pillars which would allow the down bars to run cleanely down the ft. pillars somewhat hidden...........
Re: cage pics thru dash a body [Re: Thumperdart] #1378025
01/29/13 02:21 AM
01/29/13 02:21 AM
pacific northwest
pacific northwest
exactly.. I want them to be as hidden as possible
Re: cage pics thru dash a body [Re: Stroker Scamp] #1378026
01/29/13 02:56 AM
01/29/13 02:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Not a A body but I couldnt go any closer... I had a hard
time getting the trim back in
Re: cage pics thru dash a body [Re: MR_P_BODY] #1378027
01/29/13 02:48 PM
01/29/13 02:48 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Not an A-Body either but mine is an E-Body. As mentoned can't get any closer to weld around or get the trim piece back on.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: cage pics thru dash a body [Re: 6PKRTSE] #1378028
01/29/13 04:16 PM
01/29/13 04:16 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Here are mine in my Dart.
Re: cage pics thru dash a body [Re: 70HemiGTX] #1378029
01/29/13 05:27 PM
01/29/13 05:27 PM
michigan
jbmopars Offline
jbmopars  Offline
michigan
Here's my version, any tighter and I couldn't get the screws back in the trim. I probably had the a pillar tube in and out of the car twenty times to get the dash pad the way I wanted it. I had to weld it in with a pencil torch.
[image][/image]
[image][/image]
[image][/image]
[image][/image]
Re: cage pics thru dash a body [Re: jbmopars] #1378030
01/29/13 05:35 PM
01/29/13 05:35 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Mine went through the metal part of the dash. I did some additional metal work to make the bar blend into the dash.
Here is what it looked like before the dash went back in.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: cage pics thru dash a body [Re: DusterDave] #1378031
01/29/13 05:52 PM
01/29/13 05:52 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
jb that looks REAL good
Mopar Performance
Re: cage pics thru dash a body [Re: jbmopars] #1378032
01/29/13 05:53 PM
01/29/13 05:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That is SUPER NICE... now I'll ask... where is the
slit in the dash pad or did you use that vinyl repair
to hide it... looks super nice... I think the best
I ever seen
Dave I like how you molded in the dash to the bar
Re: cage pics thru dash a body [Re: MR_P_BODY] #1378033
01/29/13 06:23 PM
01/29/13 06:23 PM
michigan
jbmopars Offline
jbmopars  Offline
michigan
There is no slit in the dash pad, the tubes went straight down through the windshield opening, through the dashpad and dash, and then were rotated into the halo. Lots and lots of test fitting and meticulous notching and trimming. It took alot of patience but I knew how I wanted it and would except nothing less.
Re: cage pics thru dash a body [Re: jbmopars] #1378034
01/29/13 06:36 PM
01/29/13 06:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... you have WAY MORE patience than me.... like I
said thats the best I ever seen...... VERY NICE...
but I built my chassis(full tube chassis) then set
the body on... then added the dash
Re: cage pics thru dash a body [Re: MR_P_BODY] #1378035
01/29/13 06:55 PM
01/29/13 06:55 PM
michigan
jbmopars Offline
jbmopars  Offline
michigan
Thanks Mike, through all the cusing and swearing, bitching and moaning, and second guessing myself as to "Why I didn't take the easy route" the work pays off when somebody like you notices. Thanks again Jody
Re: cage pics thru dash a body [Re: jbmopars] #1378036
01/30/13 04:24 AM
01/30/13 04:24 AM
Chesterfield Twp. Mi.
John Burdine Offline
after seeing how Jody did his, i see that mine is a train wreck.
Re: cage pics thru dash a body [Re: jbmopars] #1378037
01/30/13 11:49 PM
01/30/13 11:49 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
Jb Im very glad you posted that pic along with the fact that you had that one bar in and out of the car so many times.
All guys want that nice of a fit but think that you should be able to do it in 1 try. And flip out when you tell them what it will cost. Quality work cost. Very nice work by the way!
Re: cage pics thru dash a body [Re: Hitman340] #1378038
01/31/13 02:46 PM
01/31/13 02:46 PM
Harrison Township, Michigan
Hemi SS Offline
Hemi SS  Offline
OK I'll bite. How much to do 68 Dart in moly (8.50 Cert) with swing out door bars? The car is stripped to a bare shell at present
Re: cage pics thru dash a body [Re: jbmopars] #1378039
01/31/13 03:01 PM
01/31/13 03:01 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
That's CRAFTSMANSHIP right there!
Great job and great looking work and car!
Re: cage pics thru dash a body [Re: John Burdine] #1378040
01/31/13 03:05 PM
01/31/13 03:05 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I guess train wreck would be a pretty fair description of mine as well.
It showed me that things like that should be left up to professionals with the patience of a saint.... and am very happy that most of my handiwork is covered up and hidden from sight.
Re: cage pics thru dash a body [Re: John Burdine] #1378041
01/31/13 06:30 PM
01/31/13 06:30 PM
michigan
jbmopars Offline
jbmopars  Offline
michigan
Hey John, even if your dash bars don't fit perfect, every other aspect of your car is perfect looking. I can't wait to see it in person, hurry up and get it done. Thanks Jody
Re: cage pics thru dash a body [Re: jbmopars] #1378042
01/31/13 06:47 PM
01/31/13 06:47 PM
michigan
jbmopars Offline
jbmopars  Offline
michigan
Thank you everyone, I am a fabricator for a living, so where most people walk up to a car and notice the level of the body and paint, I walk up to a car and notice the fabrication skills. I have looked at hundreds and hundreds of cages over the years and the one thing most of them have in common is the fit thru the dash is marginal. I knew that if I noticed the fit on others cars that others would notice the fit on mine, so I tried to make it nice. Thanks again Jody
