Electrical Upgrades and Wiring Layout #1377772
01/28/13 09:37 PM
01/28/13 09:37 PM
Charleston, SC
bronco9588 Offline OP
Charleston, SC
Howdy. Looking at redoing the wiring of my charger. I have off for about 4 months and would like to knock out some of the more tedious things to do... Anyways, I have read all of moparts and madelectrical's tech pages. I am still scratching my head at the overall layout and a general schematic for automotive electrical. Amongst other things, I would like to mount my battery in the trunk of the car. Is there a good book that goes through car electrical design, like how to ground the car? I want to make sure I am doing things right the first time, but honestly don't know much about it. Any good books out there to get started?
'73 Charger Petty Blue, Black Vinyl, and Gill Slits 727 torque-flight 400 BB Chrysler 8 3/4 rear
Re: Electrical Upgrades and Wiring Layout [Re: bronco9588] #1377773
02/02/13 12:33 PM
02/02/13 12:33 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
When I did mine. My goal was to make the system capable of safely and easily running a significantly higher accessory load without permanently altering the factory layout. I essencially added a high amp circuit to feed everything and mounted it under the hood. As you know, the battery only starts the car, the alternator feeds your electrical system when the car is running.
In a nut shell, I created a new high amp circuit that starts from a modified AC Delco CS 144 with remote voltage sensing, and is fed to a main distribution panel that feeds all the high-amp draw circuits I added under the hood.
The car's original main electrical circuits are fed from the main distribution point just like another circuit. I have no high amp draw inside the cockpit or the rest of the car.
Everything is fused, all the sub-circuits, all the main power cables everything! I use relays on all high amp draw items including the headlights, fans, fuel pump, a/c, etc.
The rest of the car's original wiring is fed my high-amp underhood main circuit, but since the headlights and a/c blower are fed under the hood, only low amp circuits remain inside the cockpit. These are fed via the original amp guage circuit, or main power fed through the factory bulkhead. I bypassed the amp gauge and had my amp gauge converted to a volt gauge. Aside from the healight and a/c relay circuits, the amp guage bypass is the only alteration to the factory wiring inside the car.
My battery is in the trunk. I have a high amp fuse protecting the main power cable, full time. My fuel pump is fed via a fused, key-switched, oil-pressure cut-off switch protected dual 40 amp relay from the battery.
The entire "added on" electrical system can be easily removed and returned to stock configuration in a short time by taking out all my add-on stuff, mounting the battery and cables back in the stock location and simply replacing and plugging in the factory underhood wiring harnesses. I'd also have to replace the factory amp gauge and remove the headlight and blower motor relay wiring etc.
