Hello Six Pack carb guys,
My 440-6 is running pretty good at the moment after having had the carbs recently rebuilt. It idles well and has no problems while accelerating or driving normally.
The only issue I have is that when I go to stop at a stop sign or light when going downhill ...or when I have to brake to stop quickly ... I feel the car *almost* stall (rpms drop down and sounds for about a second or two like it almost dies), then it picks back up and is fine once I do stop. Again, this happens only when braking to a stop suddenly, or going downhill and coming to a stop. Otherwise, it's fine.
Does this sound like the floats are not set correctly? If so, would it most likely be the Center that is doing this or the Outboards also? Or possibly something else? It's a 4-speed car, if that makes a difference.
Thanks a lot for any advice!
