Cracked.... Is This Common On These Heads ??
#1377291
01/27/13 09:40 PM
01/27/13 09:40 PM
Posts: 2,655 western PA
mopar4ya
western PA
Getting a set of 906's prepped and have found one of them to have cracks down through the rocker shaft pedestal. Is this a common place for these to crack? These came off a 500 CI 440 that hadn't run much. It has roller rockers and was running a mild street cam. Nothing real wild in this engine, is there something I should be look at that might have caused this. I have no history on how this engine was run, new owner bought the car as non running and brought me the engine. Thanks Dan
Re: Cracked.... Is This Common On These Heads ??
[Re: mopar4ya]
#1377292
01/27/13 09:46 PM
01/27/13 09:46 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
I've seen a lot of the 906 crack externally (freeze cracks probally) under the center two exhaust ports but I have not seen what you have I would think that maybe somebody use to long of fasteners on the rocker arm shafts bottoming them out and then overtighten them to boot what else is wrong with it so far?
