70 challenger center console
#1377121
01/27/13 03:08 PM
01/27/13 03:08 PM
Posts: 41 East Concord,NY
BURNTOJO
East Concord,NY
Im in the process of doing my interior. Im trying to figure out the specifics on a 1970 center console for a 4 speed. I have a few im trying to make a good one out of. This is what I THINK I know-
* seat belt hole in back was 70 only (71 and up had ash tray) * center woodgrain piece had 4 mounting holes(71 and up had 5) * Hole in center woodgrain panel was bigger an had the left side corners slightly rounded for a 4 speed. * Botton half of console was cut out higher where 4 speed boot is.
So-am i right so far? I have one bottom console piece with plastic loops attached to side i believe to run seat belts through. Is this a 70 only or is it another year? And i believe i need two brackets to mount it to center 4 speed hump? If anybody has any info i would really appreciate it! Thanks!
70 340 challenger FK5
Re: 70 challenger center console
[Re: BURNTOJO]
#1377123
01/28/13 05:04 PM
01/28/13 05:04 PM
Posts: 434 sweden
cuda-sweden
sweden
* seat belt hole in back was 70 only (71 and up had ash tray) * center woodgrain piece had 4 mounting holes(71 and up had 5) * Hole in center woodgrain panel was bigger an had the left side corners slightly rounded for a 4 speed. * Botton half of console was cut out higher where 4 speed boot is. So-am i right so far? I have one bottom console piece with plastic loops attached to side i believe to run seat belts through. Is this a 70 only or is it another year? And i believe i need two brackets to mount it to center 4 speed hump? If anybody has any info i would really appreciate it! Thanks!
123 i say yes.4 dont know.on the straps i say -not -70, later year..
[Re: cuda-sweden]
#1377125
01/29/13 10:03 AM
01/29/13 10:03 AM
Posts: 1,652 Calgary, Alberta Canada
m46rat
2, NO, it was in 1972 that the fifth hole was added in the console and also the top plate. Also, in 1972 and up production, there is a hole cast into the rear third or the console on the side for a seat belt loop that was push mounted into each side of the console.
[Re: BURNTOJO]
#1377128
02/01/13 06:52 PM
02/01/13 06:52 PM
Posts: 1,489 west kentucky
gomangoRTSE
west kentucky
Let me ask this, will the top part of the plastic console 70 model screw into the bottom of another year or visa versa? I ask cause out in my garage I have some consoles of various years. I think I have a few broken pieces and need to work something out. Automatic transmission style consoles all of them.
[Re: BURNTOJO]
#1377131
02/03/13 02:27 AM
02/03/13 02:27 AM
Posts: 4,785 Ontario, Canada
mccannix
Ontario, Canada
From what i have found out is that you can not swap a 70 top with a different year bottom. The tabs on the 71 and up bottom are locatedin the same spots-but they are at a different height. The 70 top will not sit down flush with the bottom.
Pictured differences in tab mounting locations that show you cannot mount a 70 top to later bottoms
