What grease to use on rear wheel bearings? #1376762
01/26/13 09:42 PM
01/26/13 09:42 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
I disassembled to check the backlash on my 8.75 diff (3.91 sure grip) and will be re-installing everything tomorrow. I packed the rear axle bearings about 12 years ago, but was wondering if there is a better bearing grease to use.
(drum brakes).
Re: What grease to use on rear wheel bearings? [Re: jsully] #1376763
01/26/13 10:10 PM
01/26/13 10:10 PM
The Kendall "blue" grease is high quality as is the MP "green" grease. both come in tubes to slip in your grease gun. Then $5 needle zerk fitting on the end of the grease gun nozzle works well for bearings that are already installed.
Re: What grease to use on rear wheel bearings? [Re: RapidRobert] #1376764
01/26/13 11:34 PM
01/26/13 11:34 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
Thank you. I will head into town tomorrow to find this.
Re: What grease to use on rear wheel bearings? [Re: RapidRobert] #1376765
01/27/13 07:08 PM
01/27/13 07:08 PM
God's Country Maryland
GODSCOUNTRY340 Offline
That Kendall blue is the best. L-427
