Re: 727 TF [Re: cjs69mope] #1376512
01/27/13 04:12 PM
01/27/13 04:12 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
When I built my trans I planned to use the billet front drum and ultimate sprag. The unexpected expense was the billet front gear. When I pulled the trans apart, several if the gear splines fell out. This was just from pushing a 4,150# Charger into the high 11's.
Re: 727 TF [Re: PRZ] #1376513
01/27/13 05:24 PM
01/27/13 05:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I do understand where you guys are coming from, but i don't think a 800HP 3500lb B-body is a MILD Street Car. I'm looking for something that could last for some duration.
Sorry I missunderstood. But Cope can build whatever you need. Ron
Re: 727 TF [Re: 383man] #1376514
01/27/13 05:36 PM
01/27/13 05:36 PM
N.Y. Tioga
P
PRZ Offline OP
PRZ  Offline OP
P
N.Y. Tioga
hey man ,no need to be sorry. It's all good
Re: 727 TF [Re: PRZ] #1376515
01/27/13 06:17 PM
01/27/13 06:17 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Cope, Dave Smith at Pro Trans, A&A Alision, hard to go wrongt with any of them, they all have an excellent rep for a reason
Re: 727 TF [Re: VernMotor] #1376516
01/27/13 06:45 PM
01/27/13 06:45 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
http://coperacingtrans.com/
absolutely. John is the BEST guy for your trans needs,he helped me huge! needed a tranny asap to install before a big cruise i was going to,he built and had my new tranny in my hands exactly like ha said,and my tranny performs flawlessly.and customer service is the best,you will most likly only talk to john
Re: 727 TF [Re: meepmeep70] #1376517
01/27/13 09:06 PM
01/27/13 09:06 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
A&A Transmission
Can't go wrong with the leading "manufacturer" of aftermarket transmission parts.
Re: 727 TF [Re: nss guy] #1376518
01/27/13 10:48 PM
01/27/13 10:48 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
A&A Transmission
Doesn't CRT buy most of the parts they sell from A&A?
Re: 727 TF [Re: moparguy7074] #1376519
01/27/13 11:14 PM
01/27/13 11:14 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Find a local builder thru your car club or racers in the area. I used to build my own until a guy pointed out to me some things I didn't do correctly. He has built my last 2 and the most I have spent is $1600.
Re: 727 TF [Re: cjs69mope] #1376520
01/28/13 02:38 PM
01/28/13 02:38 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Get the 727 hand book Cope helped write it.
I used it and all the parts from cope to build a nice street strip trans.
Cope rebuild kit red alto clutches and koleen steels.
billet servos
tf2 or manual valve body
4.2 lever with heavy duty strut
red lined bands
steel planetary
pump modifications done at home per the hand book.
6000 Rpm Governor if using auto shift .
put the the money into the parts and build yourself 727 easy to do.
this is what i did and then there is my friend has a bone stock trans
behind a blown 440 with just a manual valve body for 200 bucks and the trans has held up with street and strip driving so far 10 plus years.
a good trans to start with is key .
Thanks for the kutos, But I did NOT help wright the 727 HandBook, Carl Munroe is the author.
Re: 727 TF [Re: moparguy7074] #1376521
01/28/13 02:54 PM
01/28/13 02:54 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
I do sell some A&A parts, I would not say MOST, not even close. I have been maken my own parts in house for years. My son Johnny on the mill.
