T.A. chally- torque converter hub won't fit in crank
#1376385
01/26/13 04:03 PM
01/26/13 04:03 PM
Posts: 2,141 junction city oregon
viperblue72
HI all. I just went over to help a friend on a t.a. challenger. The converter hub is too big for the crank. So my question is, does a 4 speed crank not allow for an automatic? I've never had this problem. Also what would be the best solution?
Re: T.A. chally- torque converter hub won't fit in crank
[Re: viperblue72]
#1376386
01/26/13 04:06 PM
01/26/13 04:06 PM
moparpollack
Lil Herman
Lil Herman
85086
Get a different converter.
[Re: ricomondo]
#1376389
01/26/13 04:42 PM
01/26/13 04:42 PM
Posts: 7,595 TX , NJ , FL
WINGCARS_6970
TX , NJ , FL
Had that same trouble with 273 crank
1969 Daytona 440 L9B410772
1970 Coronet 500 383 Presently owned
1970 Superbird 440 U 166242
1970 Superbird 440 U 174597
1970 Superbird 440-6 V 179697
1970 Coronet RT 440 U 224126
1968 Road Runner 426 J 134509
1970 Daytona Replica 318 G 178701
[Re: WINGCARS_6970]
#1376390
01/26/13 04:54 PM
01/26/13 04:54 PM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
Here's the pilot bushing and oilite bushing together. The oilite bushing is the one in the center of the pilot bushing. These have to come out of a 4spd crank to get an auto trans to mate properly.
GY3 71 Demon 340
[Re: ricomondo]
#1376391
01/26/13 04:55 PM
01/26/13 04:55 PM
viperblue72
Is the oilite bushing from the 4spd still in the crank?
The crank is the same for the 4 spd and auto on the T/A block.
On a 4 spd car, there's a pilot bushing, and inside the pilot bushing is a small copper/brass bushing. The pilot bushing along with the oilite bushing have to come out of the 4spd crank for an auto input shaft to fit.
NO bushing is still in the crank. It just has a pilot hole. The crank is not original I don't believe. It is a t.a. block but the crank isn't the same as all the 340 cranks I have(hole for converter hub is much smaller). So my only guess is that it is a 273/318 crank out of an earlier block?
[Re: viperblue72]
#1376395
01/26/13 07:17 PM
01/26/13 07:17 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Measure the bore of the converter hub register in the end of the crank, it should measure 1.810"....if it measures 1.550" it is a 273 crank. If it does measure 1.810" them measure the hub on the converter, it might be oversized.
In some rare cases a standard trans crank won't have the register bored at all.
[Re: John_Kunkel]
#1376396
01/26/13 07:40 PM
01/26/13 07:40 PM
viperblue72
The crank hole is definitely without doubt smaller. My other 340 cranks are very noticeably bigger and machined better. We've tried a few different converters. I can not get a pic since the car is at my friends house 10 miles from here. I am sure this is a older style crankshaft with smaller hole. Now it's just a matter of what the best solution is. Machine the crank, or find a converter? Although the early 727 is different Thank you guys for input.
[Re: viperblue72]
#1376397
01/26/13 09:25 PM
01/26/13 09:25 PM
Posts: 276 NY
aarmaniac
NY
I had the same problem when building a street motor for my AAR. Solution was pulling the motor apart and machining the crank to fit the hub on the converter. Some mentioned using a grinder to do it in the car but I did not think that was the best idea.
F.A.S.T. Legal AAR Cuda 11.57 @ 118 mph 1.72 60"
[Re: aarmaniac]
#1376399
01/26/13 11:05 PM
01/26/13 11:05 PM
viperblue72
This is what I was afraid of. It will be a lot of work, but worse things happen. Thanks guys.
[Re: magiccuda]
#1376401
01/26/13 11:55 PM
01/26/13 11:55 PM
Posts: 276 NY
aarmaniac
NY
If I remember correctly the difference was around .250 or so. It was a major setback, not one I will overlook again.
[Re: rowin4]
#1376402
01/27/13 12:01 AM
01/27/13 12:01 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Is a converter available for the smaller crank hub? Pulling the engine, then the crank for replacement or hub machining is a lot of work and dollars . A new converter would be cheaper.
No, the input shaft is smaller too.
