Re: Triple Black Bee
[Re: AZ_A12_BEE]
#1376114
12/12/13 09:01 PM
12/12/13 09:01 PM
Posts: 2,230 restos just aren't my thing
gtsuperbee
can't wait to see it in person. I'm at all the shows, come up and BS with me at one of them.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
[Re: gtsuperbee]
#1376115
12/15/13 01:09 AM
12/15/13 01:09 AM
Posts: 8,793 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Will do. I caught you a few years ago in Dalton, but it was quick because it was friggin cold out!
1969 Dart GTS 340 1969 Coronet R/T X9 N-96 1999 Dodge Dakota R/T RC 2015 Dodge Dart GT 2019 Ram 2500 Big Horn
[Re: basketcase]
#1376116
12/16/13 02:56 AM
12/16/13 02:56 AM
Posts: 299 Fitchbug, Mass.
WannaRunner
Fitchbug, Mass.
shiney paint is over rated. the way this fall has been going, I'll be in primer for a while. but I'll haver the car out having fun.
Basket, what are you running for rear springs and wheels/tires?
[Re: basketcase]
#1376118
12/17/13 05:31 AM
12/17/13 05:31 AM
WannaRunner
Fitchbug, Mass.
when I got the car, ot only had four leaves on each side, so we added a second main, and another partial. the wheels are 15x8 Cragars, with alot of offset. It rides a tad stiff, but I love the look.
Thanks!
[Re: His and Her 69's]
#1376125
02/21/14 05:48 AM
02/21/14 05:48 AM
OhioMopar
Mt.Gilead, Ohio
Will do. I was gonna call last night and see what is happening up that way. Got busy scraping gaskets, though.
[Re: OhioMopar]
#1376126
02/22/14 06:57 PM
02/22/14 06:57 PM
OhioMopar
Mt.Gilead, Ohio
Victory! Followed by defeat. Got it back together, running, and moving. Then the freeze plug on the drivers side rear of the head let go. Don't know if I'll be able to remove it and replace it without pulling the head or if I will have to yank the head. If I pull the head, I may pull both and get some work done. Hmmm...
[Re: OhioMopar]
#1376127
02/22/14 07:24 PM
02/22/14 07:24 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Hog 'em...
[Re: Shoozy]
#1376131
02/23/14 12:54 AM
02/23/14 12:54 AM
OhioMopar
Mt.Gilead, Ohio
906's I believe. Hmmm. My Dremel tool is charged...
[Re: OhioMopar]
#1376132
02/23/14 05:47 AM
02/23/14 05:47 AM
Posts: 7,066 portland or
new bee
Richard Cranium
Richard Cranium
portland or
It can be done as I did it on my Super Bee without removing the head. We used one of those long clamps often used in wood working. I'm not sure what they are properly called, but there is a hand crank on one end. In a nutshell, we adjusted the clamp to be roughly the width of the head. On the non-crank side, we replaced the end piece with a bolt. Next, we lined up the crank end with the front freeze plug, and the bolt with the back freeze plug. As we tightened up the crank, the bolt pivoted the rear freeze plug out. To install the new plug, we replaced the bolt with a flat washer the same diameter as the plug. Tightening the hand crank pressed the new plug in. Worked perfect.
*1969 383 4sp. Super Bee *1966 Alfa Romeo Giulia Sprint GT *1965 Porsche 356C *2004 VW Passat Wagon *2004 Mini Cooper S *1967 Jaguar E-Type FHC
A mall cop is in our midst.
