Triple Black Bee
#1375894
01/26/13 04:44 AM
01/26/13 04:44 AM
Posts: 8,797 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Well, I have had a little time to organize my pictures and start going over the game plan on my new purchase. I couldn't be happier. Surprisingly, it is probably the roughest body I have bought in a long, long time. The good thing is that when I say that, it still means that it is a body out of Georgia, not out of Ohio. So the rough stuff is mostly up top. It does need lower quarters, lower sectoins of the extensions(doubtful I will replace the whole extension(s). It will need a couple patches in the trunk floor, at the top of the right quarter, in the drivers floor pan, under the battery tray, and probably about 20,0000 hours of blocking, sanding, and blocking and sanding again! <img src="/ubbthreads/images/graemlins/shock.gif" alt="" /> My game plan: get the brakes done. Go through the steering/bushings/rear springs/shocks. New wheels and tires. Fuel system replacement is next. Go through the trans, new seals in the rear axle, maybe change the gear, find a driveshaft, a flywheel, put a clutch in it, and find a 383(JohnRR is on that one, and hopefully we can get together on it), a radiator, and then drive the he!! out of it! I will get the body done as time and money comes available, but I don't want to do a complete tear down to do it. Probably start at the back and drop the tank and send it somewhere (possibly where I bought it) and have the everything rearward of the door post strikers done and sealed. Here are some pics. Enjoy! I'll add more as I have time... Just an idea of what I am working with.
1969 Dart GTS 340 1969 Coronet R/T X9 N-96 1999 Dodge Dakota R/T RC 2015 Dodge Dart GT 2019 Ram 2500 Big Horn
Re: Triple Black Bee
[Re: OhioMopar]
#1375898
01/26/13 06:34 AM
01/26/13 06:34 AM
OhioMopar
Mt.Gilead, Ohio
Now on to the problem areas. The top of the quarter is a little holy... This and the lower portion makes me think very hard about replacing it with a factory style quarter. Especially when you add in the back window rust. I'm guessing the whole window channel and dutchman panel as well as corners. But then again, it isn't apart yet. Preparing for the worst. You can see the only piece of missing windshield molding I have to find. The car is pretty complete. Someone added some really cool(not) aftermarket hood pins. Luckily for me, they are in the factory location. If it will look okay with a set of the right ones on it, I may leave pins on. Just not those. Not sure if you can see the holes hacked in for the pins. Air box is complete. Believe it or not the seal is kinda brittle. Passenger door. I'm thinking of finding a set of rust free western doors. I think those I should be able to find. Would like to replace the fenders, too, but they are probably made of the ultra-rare unobtanium.
[Re: OhioMopar]
#1375899
01/26/13 06:50 AM
01/26/13 06:50 AM
OhioMopar
Mt.Gilead, Ohio
Now residing in its new home until I get it roadworthy. Gotta love the snow tires. Missing one stud... ...make that three. Ick. Ick again. Right front. Strangely, and I thought a got a picture, the left front had nothing but a wheel cylinder in it. It probably did not brake very even. Progress! Sorting and getting ready to clean up the parts to be reused. Amazing the wheel cylinder still moved inside. Fluid was actually kinda clean. Got the bore measured and the first order of parts on the way. Time to clean up the backing plates before reassembly. No, not going to pull the axles to remove the plates. Will just clean them with a liberal amount of brake clean. Removing the axles will make a tiny snowball. Then the seals will need replaced while they are out and the snowball grows. Then with new seals and pretty backing plates there is no reason to put the old bearings back in, and man, those axle flanges look like crap! But then putting the nice backing plates on the ugly rear housing... Can't do that. Better strip it. Yep, that's how it would go. Best to just clean the plates and put the thing back together. Although I will most likely turn the drums and blast them. Maybe not in that order. Stay tuned!
[Re: HemiChallenger]
#1375901
01/26/13 10:18 AM
01/26/13 10:18 AM
Posts: 98 Md
EK2Runner
Md
Nice ride you have there , Loving the Triple black Did you find the sheet and does it have the tag ?
It's a Mopar thing , If you have to ask you wouldn't understand
[Re: scatpacktom]
#1375903
01/26/13 11:14 AM
01/26/13 11:14 AM
Posts: 5,269 NY
70440+6bbl
NY
I love your Bee! Actually, it is junk, please let me know what you paid and I'll tack on a little to help you out of the mess you got yourself into I did exactly what you are doing with both my Bee and my Swinger. Both cars had been off the road since the mid-'70's. I started with the fuel systems, then the brakes and drivetrains. They have been a real blast to beat around and folks love them as is!
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: 70440+6bbl]
#1375909
01/26/13 02:06 PM
01/26/13 02:06 PM
OhioMopar
Mt.Gilead, Ohio
This I HAD to respond to. Funny you did an A12 and a Swinger. I'm getting into a 'normal' (although I've never seen a 3x black Bee before) Bee and a GTS. Both '69's. Here is the Dart waiting its turn. I don't have any pics of them together yet. But I will eventually! Oh, as for the purchase price... It doesn't matter. A Nigerian prince just emailed me and all of my money problems seem to be over! So no news to entertain offers on it!
[Re: OhioMopar]
#1375910
01/26/13 07:08 PM
01/26/13 07:08 PM
Posts: 7,841 east side of Ohio
basketcase
east side of Ohio
nice score! yeah those aren't Ohio 1/4s. But sometimes you can't go by that. Mine came out of Michigan, and the 1/4s were junk, but surprisingly everything else is solid.
1981 Dodge D150 360 auto
[Re: OhioMopar]
#1375911
01/27/13 02:36 PM
01/27/13 02:36 PM
Posts: 5,269 NY
70440+6bbl
NY
You have a great taste in cars
