100 amp alternator #1375869
01/26/13 02:56 AM
01/26/13 02:56 AM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
got a 60 amp alternator on my mopar (3 wire) and it isnt enough at the drags with fan and waterpump msd 7al etc. what should i get? thinking 1 wire 100amp? part number would be helpful..thanks
Re: 100 amp alternator [Re: Plymouth340] #1375870
01/26/13 03:04 AM
01/26/13 03:04 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have a tuff stuff 100A square back that uses the external regulator. It came from summit:
http://www.summitracing.com/parts/tff-7509rfsp
You could use a 1-wire as well but I like to be able to use parts from the local store if I am on the road. This is one of the best upgrades I ever did to my car. One smart thing to do would be run a heavy gauge wire from the positive post of the alternator to the starter relay or where ever you are getting power for the add-on's from.
Re: 100 amp alternator [Re: Plymouth340] #1375871
01/26/13 10:14 AM
01/26/13 10:14 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
I had used one off a mid 90's pickup with a v-6. Just change the pulley over to a v-groove, was 90-100 amps
Re: 100 amp alternator [Re: 80arrow] #1375872
01/26/13 11:29 AM
01/26/13 11:29 AM
IN
ahy Offline
ahy  Offline
IN
The "souped up" squarebacks have more output at high RPM but not so much at idle. With heavy "base load" of fan, WP, fuel pump you likley need more idle output. As posted above, the later model Nippendenso is a good choice if you can adapt brackets. Also the GM case alternators are good.
With a 3 wire alternaotor, the sense wire helps compensate for voltage drop in the wiring. You loose this with one wire. With one wire, its really important to have a heavy charge wire... I'd say 6 guage minimum and bigger for a long run.
Re: 100 amp alternator [Re: Plymouth340] #1375873
01/26/13 11:40 AM
01/26/13 11:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The Denso alt works great(3 wire units) has real good
low rpm out put... 1 run a 85A Denso on both my race
car and street rod... plus I like the external reg...
why trash a alt if the reg goes bad... plus you can
get a high out put reg... I just used the Chrysler
production ones... based on where you tap your sense
wire you can get different battery voltage... I get
14.9 at the battery on my street rod
Re: 100 amp alternator [Re: Plymouth340] #1375874
01/26/13 11:49 AM
01/26/13 11:49 AM
CEDAR RAPIDS
CEDAR RAPIDS
this is drag race only, and right now i have a big pulley on alt. and the hot wire is heavy gauge ran back to cut off switch at back of car and have constant out put regulator. it dosnt charge much at idle if any
Re: 100 amp alternator [Re: Plymouth340] #1375875
01/26/13 12:08 PM
01/26/13 12:08 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I've been running a powermaster 140 amp for over 6 years. It's a one wire and I have had no issues at all, It came with an actual test sheet too that showed it put out over 80 amps at idle too. I did have to grind a little on my stock bracket to make it fit though.
Re: 100 amp alternator [Re: Plymouth340] #1375876
01/26/13 05:16 PM
01/26/13 05:16 PM
Az
Crizila Offline
Crizila  Offline
Az
Put the smaller pulley on it.
Fastest 300
Re: 100 amp alternator [Re: Quicksilver440] #1375877
01/27/13 10:06 AM
01/27/13 10:06 AM
Cleveland, Ohio
BB73Challenger Offline
Cleveland, Ohio
I too run a high amp powermaster for fans, aftermarket ign, as well as being able to add on more electronics in the future.
At idle with the fans on, Serious radio going, lights on and GPS plugged in It doesn't skip a beat.
I've been running it trouble free for many years now.
Re: 100 amp alternator [Re: Plymouth340] #1375878
01/27/13 01:25 PM
01/27/13 01:25 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use a Tuff Stuff 100 amp alt with a #4 wire to the cut off switch.Works GREAT. The one I use is the one wire with the generic Ford/GM case.
Nautilus Racing-
Re: 100 amp alternator [Re: Plymouth340] #1375879
01/27/13 01:55 PM
01/27/13 01:55 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I bought the 120 kit from mancini's it is a 3 wire run it with one feild grounded other to blue MP performance regulator (so you regulate to under dash voltage best IMO! ) # 4 to the battery and wow it works great.
Think buddy just got one from them not in kit as with me i ened up with a low mount when I went engine plate
http://chucker54.stores.yahoo.net/delialbrpk.html
now mounted like so
Re: 100 amp alternator [Re: 80arrow] #1375880
01/27/13 04:43 PM
01/27/13 04:43 PM
CEDAR RAPIDS
CEDAR RAPIDS
thats what i should do. can i still use my mopar constant output regulator with the mid 90's alternator? wired the same?
Re: 100 amp alternator [Re: Plymouth340] #1375881
01/27/13 06:22 PM
01/27/13 06:22 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
That is what I'm doing, the earlier ones have a V-belt and field connections that are bolt on later ones have serp. belts and goofy plugs for the field wires. Also the pulleys are the same as the small Delco (.665? shaft if I remember right)
This is a old pic before I went back to v-belts (after this pic I put a vac pump on it) With the smaller alt pulley it was 2.25 to 1 ratio charged great at idle, but the sudden acceleration coming off the 2 step (3600leave 5500 flash)killed one after a while. Now using a 1.7 ratio and it's happy. Hope this helps
"Just a Bracket car dressed up like a streetcar"
Re: 100 amp alternator [Re: Just-a-dart] #1375882
01/27/13 07:02 PM
01/27/13 07:02 PM
CEDAR RAPIDS
CEDAR RAPIDS
That is what I'm doing the earlier ones have a V-belt and field connections that are bolt on later ones have serp. belts and goofy plugs for the field wires. Also the pulleys are the same as the small Delco (.665? if I remember right)
what size alt and crank pulley are you running now? i trans brake my car to 5000 and dont want to be losing belts..thanks
Re: 100 amp alternator [Re: 80arrow] #1375883
01/27/13 07:15 PM
01/27/13 07:15 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
How was the output down low like at idle? I need to upgrade, bottle heater hits the factory replacement one hard. Thanks
Re: 100 amp alternator [Re: SpareParts] #1375884
01/27/13 10:02 PM
01/27/13 10:02 PM
8
80arrow Offline
80arrow  Offline
Mine seemed to charge at 1000-1200 rpm I think. I don't have the car any more so I can't tell you the pulley size. I ran water pump, fan, magna fuel fuel pump, MSD 7al2. I'd run the fan and water pump after each pass to cool it down and never put the battery charger on in two years. This was with the altenator off the 90's dodge pick-up
Re: 100 amp alternator [Re: Plymouth340] #1375885
01/27/13 11:12 PM
01/27/13 11:12 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Sorry just looked at my notes 1.7 was my target ratio. Current pulleys 4.5 crank/2.5 alt 1.8 ratio. alt pulley is a little small, but I have had no trouble.
Around a 5"crank/3"alt (1.67 ratio) would be a good place to start.
Re: 100 amp alternator [Re: Just-a-dart] #1375886
01/27/13 11:39 PM
01/27/13 11:39 PM
CEDAR RAPIDS
CEDAR RAPIDS
sounds good i have a 5 inch crank pulley now will get a new 90 amp alt with 3 inch pulley,,thanks
Re: 100 amp alternator [Re: Plymouth340] #1375887
01/29/13 01:25 AM
01/29/13 01:25 AM
IN
ahy Offline
ahy  Offline
IN
"rule of thumb" alternators redline at 16,000 to 18,000 RPM. You probably want to be at around this RPM at engine redline to keep idle output adequate. It depends a lot on the engine setup but 1.67 ratio sounds a bit low. A bigger crank pulley or smaller alternator pulley may be in order.
Re: 100 amp alternator [Re: ahy] #1375888
01/29/13 04:19 AM
01/29/13 04:19 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm on my 3rd year with this chinese GM knock off. single wire is oh so easy.
