best piston pin size? #1375815
01/26/13 02:28 AM
01/26/13 02:28 AM
QLD Australia
Keith Black® Offline OP
QLD Australia
Hi Guys, I am about to order rods/pistons & I am looking for some help on the best piston pin option.
Engine (Hemi), 7.100 (steel-Oliver) rods, 2.20 journal crank (crower) 4.500 stroke, 8.5:1 comp. supercharged < 20lbs. est hp <1500.
Options are .990 or 1.03 or? what is generally used or am I safe either way?
PS: Who is presently the best custom piston manufacturer? CP/JE?
cheers, thx for your help.
Darren Beale
Keith Black Racing Engines®
Re: best piston pin size? [Re: Keith Black®] #1375816
01/26/13 12:43 PM
01/26/13 12:43 PM
Delray beach, Florida
P
Performance Only Offline
P
A good tool steel .990 pin is plenty for what your doing. both of the piston companies you mentioned can make what you need.
I use and sell Diamond Pistons for almost all of our custom pistons, especially the higher horsepower applications.
machine shop owner and engine builder
Re: best piston pin size? [Re: Performance Only] #1375817
01/26/13 01:15 PM
01/26/13 01:15 PM
dogdays Offline
dogdays  Offline
Amen. The 2.20 rod journal and the 0.990 pin have become the de facto standard for big blocks. Deviate from that at your own risk. You'll have a much harder time finding pistons, pins, etc if you go stock Mopar on either end.
R.
Re: best piston pin size? [Re: Keith Black®] #1375818
01/26/13 03:38 PM
01/26/13 03:38 PM
Cab_Burge Online work
Cab_Burge  Online Work
As already said a tool steel pin and around .170 wall thickness
Re: best piston pin size? [Re: Cab_Burge] #1375819
01/26/13 06:53 PM
01/26/13 06:53 PM
QLD Australia
QLD Australia
thanks everyone . I'll go with .990.
Darren Beale
