TRUE HOOD SCOOP TESTS........................... #1375770
01/26/13 01:59 AM
01/26/13 01:59 AM
State of confusion
Thumperdart Offline OP
State of confusion
Has anyone actually done back-to-back at the track test on foreward facing scoops compared to cowls and what were your results......... I ordered a pin on hood instead of the heavy bolt on I have pinned on now and am considering a cowl ONLY if it`s actually faster. I would totally seal either scoop and my cowl opening is sealed off which might help the cowl..........
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375771
01/26/13 02:27 AM
01/26/13 02:27 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
I think there has been a post on here about that, send a PM to a Kiwi on here called REBEL, I'm sure he has been through this with his Valiant coupe (Dart)
Re: TRUE HOOD SCOOP TESTS........................... [Re: nz383man] #1375772
01/26/13 02:49 AM
01/26/13 02:49 AM
K
KOS Offline
KOS  Offline
K
6"cowl hood extended and trimmed back to 1.5-2"s off the windsheild sealed to carb against factory 6pac hood unsealed and no hood.
No hood won over both hoods in ET
the cowl was a tenth slower over no hood and the 6pac was about 3-4hundreds. the cowl went the best mph(1) but killed the 60ft so maybe the weight of it hurt it.we lightened the hood slightly by removing the seal to the carb but havent had a chance to go back and give er a try.
Re: TRUE HOOD SCOOP TESTS........................... [Re: KOS] #1375773
01/26/13 12:44 PM
01/26/13 12:44 PM
State of confusion
State of confusion
Ya I remember about Rebel`s deal and really would like about a 6" 6-pac scoop but havn`t really looked yet........
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375774
01/26/13 01:42 PM
01/26/13 01:42 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I would think a taller scoop, like the older pro stock scoops, with the opening higher into the main airstream, or less turbulent air would be the best. Look at all the higher scoops the pro stocks of the day ran. Just my thoughts.
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375775
01/26/13 01:56 PM
01/26/13 01:56 PM
Staten Island N.Y.
Dap Offline
Happy Birthday Dap  Offline
Staten Island N.Y.
In back to back passes my old 6 pack hood was .15 faster than my cowl.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: TRUE HOOD SCOOP TESTS........................... [Re: Dap] #1375776
01/26/13 02:07 PM
01/26/13 02:07 PM
State of confusion
State of confusion
Thankxx guys..........The ONLY way a cowl goes on my dart is if it`s way quicker. I may cut a 6-pack scoop in the middle and narrow it unless you guys think that would hamper it`s design for air flow.
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375777
01/26/13 03:28 PM
01/26/13 03:28 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know even on the 6pk scoops I heard it helped to just raise the opening a small amout of about 1/4 to 1/2" like on the 6pk scoops. Just to get the opening off the hood and raised any does help from what I hear. In other words have it so the bottom of the scoop opening is not right on the hood as I believe it works better to raise the scoop some even if only a 1/4" to get the scoop up in the air stream and get the opening off the hood itself. Like what the snorkel scoops did in Pro Stock in the 70's. Actually going by that standard means my Max Wedge scoop really dont work good at all the way it is like they were stock. I believe the trick on the front open scoops is to get the scoop up in the air flow better as flat on the hood is not as good air flow into the scoop. Ron
Re: TRUE HOOD SCOOP TESTS........................... [Re: 383man] #1375778
01/26/13 04:00 PM
01/26/13 04:00 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You can see on this pic how my Max Wedge scoop is right on the hood which does not work to good from what I know. And then my buddies areo scoop you can see where it is lifted some off the hood so the opening is not flat on the hood. This seems to work better by the way the air flows over a hood. Ron
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375779
01/26/13 04:16 PM
01/26/13 04:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
We have talked on this before so you know how I feel
on this.. but if you do the string from the front of
the hood to the roof line and stay above it your in
clean air... I havent had much work with the cowl scoops
yet but I have a cowl now on my Rampage and will start
testing this summer
Re: TRUE HOOD SCOOP TESTS........................... [Re: MR_P_BODY] #1375780
01/26/13 04:58 PM
01/26/13 04:58 PM
State of confusion
State of confusion
I remember...............I heard about the scoop opening needing to be at the BOTTOM of the scoop entrance but on a driver, I probably can`t get away with it but maybe one of those old-skool pro stock scoops could work.
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375781
01/26/13 05:04 PM
01/26/13 05:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On a daily driver I would at least try to get a portion
of the inlet above that line...any bit will help...
remember that you can move the inlet forward and get
above it... thats why you see some GM cars with the
opening right near the front
Re: TRUE HOOD SCOOP TESTS........................... [Re: MR_P_BODY] #1375782
01/26/13 07:43 PM
01/26/13 07:43 PM
State of confusion
State of confusion
Thankxxx.............I`ll see what I can get away with.
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375783
01/26/13 08:39 PM
01/26/13 08:39 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
heres mine Dom ----------
Re: TRUE HOOD SCOOP TESTS........................... [Re: 493_DART] #1375784
01/26/13 09:17 PM
01/26/13 09:17 PM
tboomer Online work
tboomer  Online Work
A little humor for ya,Dom...That is where Kevin parks after drinking that cheap swill he calls beer...Notice the mens restroom...
Re: TRUE HOOD SCOOP TESTS........................... [Re: tboomer] #1375785
01/26/13 10:06 PM
01/26/13 10:06 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Dom just thinking out loud here wile having a couple So I hope it don't turn into a fest on me
Hows 'bout (I'm not a fan of them either) a cowl scoop closed off at the back with 2 custom air inlet scoops on each side in the front.
Maybe you could graft something like a pair of Cuda or Chally style scoops in there. Who knows maybe the nose of your 6 Pack scoop can be grafted near the front.
It would be low and street friendly and pick up some air from the nose of the car.
It would certainly be original
Or maybe I need
Re: TRUE HOOD SCOOP TESTS........................... [Re: roadhazard] #1375786
01/26/13 10:35 PM
01/26/13 10:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A car's nose (in the '60s-'70s) pops the high-pressure air up in an arc that hits the top half of the windshield. That's why there's lower pressure at the cowl. The air closest to the hood is not effective for ram-air; about an inch above the hood is where you start to get into high pressure. There's a drag penalty for too big, too high, too large an opening. Ducting air from the grille area is pretty effective, but it gets heated on its way to the carb, and intake holes & packaging can be a problem.
Look around on the web for the aero test pics on the Mopar Missile Duster, where they tried different scoops.
Re: TRUE HOOD SCOOP TESTS........................... [Re: 493_DART] #1375787
01/26/13 11:16 PM
01/26/13 11:16 PM
State of confusion
State of confusion
Can you see around that thing on the street and what about the po-po........(ghetto for police).
Re: TRUE HOOD SCOOP TESTS........................... [Re: roadhazard] #1375788
01/26/13 11:20 PM
01/26/13 11:20 PM
State of confusion
State of confusion
Maybe you could graft something like a pair of Cuda or Chally style scoops in there. Who knows maybe the nose of your 6 Pack scoop can be grafted near the front. Hey Ted, too funny.............
Or maybe I need
If only I was that talanted........ See what beers do to ya? Still drillin and lightning my dart so when my new hood`s done I`ll try a few different scoops or just get the tallest 6-pack I can find........
Re: TRUE HOOD SCOOP TESTS........................... [Re: tboomer] #1375789
01/27/13 12:10 AM
01/27/13 12:10 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
you drink busch light....
That must be what you country folk call "good beer "
Dom--i can see fine around the scoop
