'67 440 with open chamber heads??? #1375389
01/25/13 12:59 PM
01/25/13 12:59 PM
Chester, VA
tobnHisglory Offline OP
Chester, VA
I just purchased a 440 from a 1967 Imperial. I was pretty excited since it was a 78,000 original mile motor. Checked the block casting date and it was 10*5*67 so I was expecting 915 heads. I just got it pulled apart today and found open chamber heads. The part number is hard to read and needs more cleaning, but looked like 26438062. The closest I can find listed anywhere is the 2843904 listed as a 68 440 head. What's more, the ID pad is stamped D440, with 10 30 bellow that and a sideways A stamped to the right of it. Wasn't D a '68 block? Anyone have any ideas?
Really bummed about it not being closed chamber heads...
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: '67 440 with open chamber heads??? [Re: tobnHisglory] #1375390
01/25/13 01:03 PM
01/25/13 01:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The 10-5-67 was a solid clue, 68 engine production started arounf the fifth or sixth month of 67... And yes D is 68...
Re: '67 440 with open chamber heads??? [Re: 1_WILD_RT] #1375391
01/25/13 02:14 PM
01/25/13 02:14 PM
Chester, VA
Chester, VA
I keep reading that an A on the ID pad means oversized bores. But has anyone seen the A off to the right and stamped sideways before?
Just seems odd that a '67 casting date 440 would have such a late assembly date and be stamped for a '68 model year but be found in a 67 car.
-Reggie
Re: '67 440 with open chamber heads??? [Re: tobnHisglory] #1375392
01/25/13 02:21 PM
01/25/13 02:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The car is 46 years old, lots of stuff happens in 46 years... Maybe it had a piston come apart under warranty in 68... Maybe it had a rod knock in the 70's... Whatever happened the engine got swapped...
Re: '67 440 with open chamber heads??? [Re: 1_WILD_RT] #1375393
01/25/13 02:42 PM
01/25/13 02:42 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I have a 440 from a 1967 IMP and it has closed chamber heads...Just freshened it up waiting for warmer weather to install it..but it had smaller ex valves than my 906 heads..Can't remember the head numbers !!
Re: '67 440 with open chamber heads??? [Re: dynamite] #1375394
01/25/13 02:43 PM
01/25/13 02:43 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Should have 915 heads & the big valves are an easy upgrade....
Re: '67 440 with open chamber heads??? [Re: tobnHisglory] #1375395
01/25/13 04:17 PM
01/25/13 04:17 PM
dogdays Offline
dogdays  Offline
Yup, bad assumptions...The D indicates a 1968 model year engine. The casting date is WAAAAAY too late for a 1967 model year car.
Post the engine ID pad information, all of it, and any partial VINs that are stamped into the block.
Engine got swapped at some point, or else the car really was a 1968.
R.
The heads are 2843906 casting nuber heads, otherwise known as "906 heads". They are what I'd expect to see.
Now each head has a casting date somewhere on it, the last digit should be a 7 for the 1967 date of the casting.
Re: '67 440 with open chamber heads??? [Re: dogdays] #1375396
01/25/13 06:36 PM
01/25/13 06:36 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Somebody swapped the motor or maybe the car is a 68. I don't think the average "mopar guy" on moparts knows what a 67 Imperial looks like.
Re: '67 440 with open chamber heads??? [Re: 440newport] #1375397
01/25/13 10:08 PM
01/25/13 10:08 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
67 Imp. Notice the lack of side lights.
Kevin
Re: '67 440 with open chamber heads??? [Re: Twostick] #1375398
01/25/13 10:09 PM
01/25/13 10:09 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
68 Imp has small square side lights.
Kevin
Re: '67 440 with open chamber heads??? [Re: Twostick] #1375399
01/26/13 03:30 AM
01/26/13 03:30 AM
Chester, VA
Chester, VA
Thanks for the info guys. It wasn't my car so I can't check it all out now as well as I'd like. I decoded the fender tag (took a pic of it when I bought the motor) and it says '68. The owner said it was titled as a 67 and when I saw the '67 casting date I assumed he was correct.
I'm still having a little trouble with the block ID pad as it seems a little different than the pictures/decoding diagrams I'm seeing. I'll try to take a picture of it tomorrow, but it looks like this:
-D440 -
- A -
-10 30 -
...but the A is off to the far right side and stamped sideways. That's it.
-Reggie
Re: '67 440 with open chamber heads??? [Re: tobnHisglory] #1375400
01/26/13 03:48 AM
01/26/13 03:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
-D440 -
- A -
-10 30 -
It's a 68 440 assembled on 10/30/67 , A means it is bored .020 oversize.
For some reason many people confuse the casting date for the actual model year of the engine , while that may hold true for the majority it is not the rule.
Re: '67 440 with open chamber heads??? [Re: JohnRR] #1375401
01/26/13 06:50 AM
01/26/13 06:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had a 440 block that had a 12/65 date.They didnt come out till the 66 year.The block was cast at least 7 months before 66 production.Rocky
Chrysler Firepower
Re: '67 440 with open chamber heads??? [Re: therocks] #1375402
01/26/13 07:45 AM
01/26/13 07:45 AM
Maud,Tx
maud Offline
maud  Offline
Maud,Tx
The 915 castings were used on '67 GTX and Coronet R/T HP engines. Most if not all other 440 equipped cars in '67 came with 516 casting heads, which are closed chamber but have smaller exhaust valves.
Re: '67 440 with open chamber heads??? [Re: maud] #1375403
01/26/13 08:25 AM
01/26/13 08:25 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I don't think that is correct. Most 67 440s came with 915's, but the the non-hp version had the small exhaust valve.
Re: '67 440 with open chamber heads??? [Re: BSB67] #1375404
01/26/13 11:28 AM
01/26/13 11:28 AM
Maud,Tx
maud Offline
maud  Offline
Maud,Tx
I stand corrected, you are right. The 516's were used prior to '67. Sorry.
Re: '67 440 with open chamber heads??? [Re: therocks] #1375405
01/26/13 12:39 PM
01/26/13 12:39 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
The model year ran August of 65 to July of 66 so a December 65 block would be right in the middle of the 66 model year production.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: '67 440 with open chamber heads??? [Re: therocks] #1375406
01/26/13 06:16 PM
01/26/13 06:16 PM
ill
dennismopar73 Offline
ill
I owned a 6/65 440 block , came out of a 65 year car, IDONO??
Re: '67 440 with open chamber heads??? [Re: dennismopar73] #1375407
01/26/13 07:11 PM
01/26/13 07:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Model year and Calender year have nothing to do with each other.
the 440 premiered with the 66 MODEL YEAR Chryslers.
Don't be the exception.
