A Body SB to BB conversion
#1375312
01/25/13 04:24 AM
01/25/13 04:24 AM
Posts: 104 Arkansas
Nimbus426
Arkansas
What's better: Schumacher A body conversion mounts on a small block k frame or original big block A body k frame?
My small block k frame is damaged, so I'd have to get that repaired anyway along with modifying it so it'll work with the schumachers. BUT my other option is a guy wants to sell me an original A body BB k frame for $250. I'd still need to buy mounts for it though. And I also heard that the original style mounts will only bolt into certain engines.
Trying to decide which would be less of a headache and better in the long run. Thanks
-ERIC
Re: A Body SB to BB conversion
[Re: Nimbus426]
#1375313
01/25/13 11:00 AM
01/25/13 11:00 AM
RapidRobert
Welcome here! I did one with the Schumaker conversion mounts (69 valiant 383) where you slightly ground on the K member pedestal mount on the DR side iirc & it was easy/trouble free. I'd say go that way except in your case you need to remove/repair your current K member. Yes iirc I believe you need to use a block with either the drilled bosses on the front side or undrilled bosses & drill them. The front bosses may only be on '66 blocks & someone will clarify that for you. I'd start by pricing a set of the mounts & an appropriate block & $250 for the Kmember & comparing that to the Schumaker mts & a repaired (or another one) Kmember. As you know the hard part ($$$) will be locating the block with the bosses. I think going with the Schumaker setup will be the easiest. I'd be leery of the current damaged one especially if it is mangled to the point where it needs removed to fix it.
[Re: JohnRR]
#1375317
01/25/13 02:39 PM
01/25/13 02:39 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
That's what I needed to hear. I think I'll go with the Schumacher mounts. My K Frame isn't damaged too bad..it looks like someone didn't bolt a motor in there tight enough so it tore it up around the bolt holes. If I need a new one I know where to find one. Thanks for the input!
-ERIC
[Re: RapidRobert]
#1375320
01/25/13 09:19 PM
01/25/13 09:19 PM
Posts: 4,959 WI
Dcuda69
WI
Just to clarify...the bosses on the front of the blocks for the BB k-frame seem to be hit and miss. I have a 74 400 block(stroked to 470)in mine on a original BB k frame....the bosses were there and drilled! $250 for a good BB k-frame is a good price...I paid more than that but mine had the mounts,etc.
With all that said I would do the Schumacher or DC conversion...wish I would have. With THAT said.....BB A-bodies are a hoot to drive!!! ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Cab_Burge]
#1375321
01/26/13 12:44 AM
01/26/13 12:44 AM
Posts: 168 Washington State, USA
Winchester 73
I would and do use elephant ears to do that conversion I have a original GTS 383 1969 Dart, if the block your going to use doesn't have the two cast in threaded bolt bosses on the very left front of the block your motor wouldn't work in a original car. The spool mounts are a little better deal due to being able to use any BB block. My Duster, and several other A bodys I have had or built used th elephant ears
i second the nod to elephant ears -its easy and fun.seems to tie the car together very well becose it makes the engine part of the cars structure.
[Re: Winchester 73]
#1375322
01/26/13 01:49 AM
01/26/13 01:49 AM
Posts: 104 Arkansas
Nimbus426
Arkansas
Thanks for all the advice! I didn't even think about elephant ears. I think I'll give that a shot. I'm still trying to find an 8 3/4 that doesn't cost $1,000. I've heard mixed opinions about making B Body rears fit, so I'm thinking of waiting for a good deal on an A Body rear to come up.
-ERIC
[Re: Nimbus426]
#1375323
01/26/13 12:46 PM
01/26/13 12:46 PM
Posts: 738 Columbus Ohio
mopfried
Columbus Ohio
What else do you have planned for the A body? If you think u may ever move the springs inboard and or a mini tub buy any 8-3/4 rear and cut it down so you can run some meat it the rear to put that BB to the ground!! ![](/ubbthreads/images/graemlins/drive.gif) I have a 74 scamp with a 440. It's not tuned just right yet and it is a blast to drive! You may also wanna tie the frame rails. I did the DC k frame conversion with a spool mount k frame. It would be easy to do while you are swapping k frames if you can cut and weld. Elephant ears may give more room for headers... Don't know of any drawbacks from using them. Big block dart tech pages is a good source of info for a bb conversion.
[Re: mopfried]
#1375324
01/26/13 02:16 PM
01/26/13 02:16 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
When I found the car it was so straight I had no choice but to buy it. The only rust on the car was on the passenger side floor pan. And the car was complete. Because of that I don't want to do too much cutting or drilling for modification. So I might do subframe connectors and a big block conversion, but I don't want to mess up it's original metal too much. But I can't wait to drive it! I've heard about how much fun BB A Bodies are and I've wanted one since I was a kid. This is a picture of when I first bought it. It was parked back behind a truck shop in the gravel for years.
-ERIC
[Re: mopfried]
#1375326
01/26/13 09:49 PM
01/26/13 09:49 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Elephant ears are a old school way to make a easy engine swap. When I first did the big block conversion to the barracuda I used elephant ears, as the car was built for a street / strip ride I found that the water pump gaskets needed replacing quite often as the ears would let the engine flex back and forth. Now we have motor plates , same basic thing but are connected in the center to help prevent engine movement . Never had a leak since. Look on Mancini web site, Get a AR Engineering { AndyF who's a member on here } motor plate. Best looking plate made. Get a lot of comments on it. Have one in both of my cars ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 70Duster440]
#1375328
01/27/13 09:38 PM
01/27/13 09:38 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Those are some sweet rides. I'll probably run my 318 in the Dart for now. It's a '68 model with a 904 automatic. I've got a 4bbl intake I might eventually stick on top. Gotta save up the cash for those BB upgrades. Thanks for all the advice!
-ERIC
[Re: Nimbus426]
#1375329
01/28/13 10:30 AM
01/28/13 10:30 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
I used the DC K-member when I did mine, but that was back in 1978 or so. I didn't know of any other way to do it. It works great, you can still find the motor mounts, spool type. Everything lines up, no issues. I used the old CPPA headers, a little tight around the trans, auto, but fit ok.
I did take the fan motor out before the swap, so cant comment on that, but it appears it would be tight.
As mentioned, make sure you put a good radiator in for the swap.
I did have to "adjust" the parting line or whatever it is called in the trans tunnel, hit the trans, but other than that, it is an easy swap.
[Re: Dodgeguy101]
#1375330
01/28/13 06:43 PM
01/28/13 06:43 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Here's another question. I found a '64 Dodge 330 parts car with an 8 3/4 rear. How hard would it be to make that rear fit in my Dart? I read that the early B Body rear ends are pretty close to the right size. The guy's asking $150 for it minus the gears.
-ERIC
