Re: Part help?? 383 w a/c bracket
[Re: shamefulcuda]
#1375153
01/24/13 08:57 PM
01/24/13 08:57 PM
Posts: 131 central,pa
ply64post
central,pa
Check out this site. http://www.hoffmanswinnerscircle.com/cat05.htm"987TAC" - 1969-74 Big Block Engine with Air Conditioning (triangle only!) - $25 Each Fits all big block water pumps. Has correct locating dimple and 5/16-18 weld nut for heater hose shield #0058. POWDER COATED semi-gloss black. Use heater hose support "0058"
[Re: ply64post]
#1375154
01/24/13 09:02 PM
01/24/13 09:02 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
that is the one that goes out in front , he is looking for the one behind it , I probably have one in my bucket o' parts ...
[Re: shamefulcuda]
#1375156
01/24/13 11:15 PM
01/24/13 11:15 PM
Posts: 6,418 Abilene, Texas
fastmark
Abilene, Texas
I know I have one laying around if I can find it. PM me and ill look tomorrow. I found it. It does not have a nut welded to the back of it, though.
[Re: fastmark]
#1375157
01/25/13 07:38 PM
01/25/13 07:38 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
You are referring to the piece circled in green correct?
Thats 383 only
If so I have that piece powdercoated in black...LMK if you want it
1MYTGTX
[Re: shamefulcuda]
#1375159
01/26/13 02:13 AM
01/26/13 02:13 AM
JohnRR
U.S.S.A.
yes that looks like it. Only thing i notice is it doesnt have nut on back side welded like the ones I've had in past. Although obviously I could put my own nut on back side. Yes, I need it if you can ship it out to me usps priority?? Should fit easily in a padded envelope. PM for price and payment info. Thanks!
It probably doesn't have a nut because the piece itself is tapped ?
