Good size tire for 15x7 #1375020
01/24/13 03:26 PM
01/24/13 03:26 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Going to buy a set of 15x7 rallys for my 70 RR. Plan to go with just some Radial TA's for now. Whats a good size?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Good size tire for 15x7 [Re: JMCFAN] #1375021
01/24/13 03:50 PM
01/24/13 03:50 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Got 255/60's on my '68 GTX....lots of room and they fill the wheel well nicely.
Anything bigger and it gets a little too much for the rim width.....I tried that.
Re: Good size tire for 15x7 [Re: JMCFAN] #1375022
01/24/13 04:17 PM
01/24/13 04:17 PM
Arkansas
beatupcuda Offline
beatupcuda  Offline
Arkansas
tall or short ? you could run 265 or 275 even 285, 70, if available, they used to be, if you want taller than a 60
Re: Good size tire for 15x7 [Re: superwrench] #1375023
01/24/13 04:34 PM
01/24/13 04:34 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Troy
Houston Mopar Connection Club
Re: Good size tire for 15x7 [Re: hemi68charger] #1375024
01/24/13 05:34 PM
01/24/13 05:34 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
I have Eagle GT IIs and 255/60s look good. I've tried 275/60s and they look fine on a 7 inch wide rim even though 8 inch is recommended.
T/As may be slightly different for height and section width but it would be minimal.
Mike.
Re: Good size tire for 15x7 [Re: JMCFAN] #1375025
01/24/13 07:12 PM
01/24/13 07:12 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Front or rear or all around? (did I miss for front or rear?)
Re: Good size tire for 15x7 [Re: A12] #1375026
01/24/13 07:21 PM
01/24/13 07:21 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
225/60-15's on 15 X 7 on the front.
255/60-15's on 15 X 8.5's on the rear.
The rear is close but still has room with original sheet metal but 275/60-15's on the 8.5" rim will rub for sure on my GTX
Re: Good size tire for 15x7 [Re: JMCFAN] #1375027
01/24/13 11:32 PM
01/24/13 11:32 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
As far as fit to rim, the tire manufactures have a recommended rim width and you'll get the most performance from a tire by staying within it.
For a 7" wide rim generally you'll be looking at 215-235 in the metric width tires.
As far as sidewall, that's really up to you. Shorter sidewall will have less give and generally feels more responsive and corners better on good pavement. Taller sidewall can keep better contact and better protection on bad pavement and off pavement.
Remember if you change the rolling radius from the current tire/wheel combo, that you'll likely need to change the speedometer pinion. Not a big deal, but worth noting.
An alternative to the BFG T/As are Firestone's Indy 500. Same catagory of tire, but a little more grip according to Tirerack's survey. I agree, but actually give less weight to my opinion because the T/As were old and seemed to be getting hard when I switched.
Re: Good size tire for 15x7 [Re: A12] #1375028
01/24/13 11:46 PM
01/24/13 11:46 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
BEAUTIFUL CAR!!
Re: Good size tire for 15x7 [Re: JMCFAN] #1375029
01/25/13 12:18 AM
01/25/13 12:18 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
BEAUTIFUL CAR!!
Thanks and quick OT it's a complete number matching with 94,000 original miles, LA plant built, sold to someone in the LA area and then ended up in your State for the rest of its life with the second owner.....I'm the third owner. A 4-spd console, 3.54 Dana, power steering, power discs, tach, 8-Track, tinted windows. Because it was a SW car most of it's life it has all of its original sheetmetal and NO RUST ANYWHERE
Now back to tires
Re: Good size tire for 15x7 [Re: JMCFAN] #1375030
01/25/13 03:09 AM
01/25/13 03:09 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
One vote more for 255/60-15s are the best match for them. Maybe 245/60-15 too
Re: Good size tire for 15x7 [Re: JMCFAN] #1375031
01/25/13 07:01 AM
01/25/13 07:01 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I ran 275/60R-15 BF Goodrich radial TA's on my 69 RR for many years. It's the biggest I'd go and they worked great for what they are. Meaning, TA's are a budget street tire that is too hard for any good track times but great for a street machine cruiser.
Went one size bigger to the old Mickey Thompson "Letter I" bias ply's that were L60-15's and they didn't want to sit flat on the pavement unless I went way down in tire pressure (like 20 psi).
Personally, the bigger the tire in the back, the better your B-body will look!
Re: Good size tire for 15x7 [Re: Dean_Kuzluzski] #1375032
01/25/13 07:34 PM
01/25/13 07:34 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
These are 255/60/15 on all 4 corners on a 15x7 rim
1MYTGTX
Re: Good size tire for 15x7 [Re: 1MYTGTX] #1375033
01/26/13 11:12 AM
01/26/13 11:12 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Re: Good size tire for 15x7 [Re: JMCFAN] #1375034
01/26/13 01:00 PM
01/26/13 01:00 PM
dogdays Offline
dogdays  Offline
31-10.50 x 15
R.
Re: Good size tire for 15x7 [Re: dogdays] #1375035
01/28/13 09:59 PM
01/28/13 09:59 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
31-10.50 x 15
R.
