Sweptline BB guys #1374909
01/24/13 04:32 AM
01/24/13 04:32 AM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Thinking of convertng my 68 over to a BB. Well I have pieces to bolt together a 511" Indy BB as well as a trans already to go and converter etc. I am now thinking of putting all this in my 68 shortbed Sweptline that now has a 318 in it.
So time for a few questions. Are there headers available for this application off the shelf? Does anyone have any pictures of a BB in a sweptlinbe. More specifically motor mount area. No real worries as I am sure we will have to do some fab work but that is not a big deal. Just thinking these parts that have been taking up space might loog good in there.
Re: Sweptline BB guys [Re: Al_Alguire] #1374910
01/24/13 08:57 AM
01/24/13 08:57 AM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
No pics but in the garage is motor mounts and oil pan for a sweptline.
Re: Sweptline BB guys [Re: crowbait] #1374911
01/24/13 01:33 PM
01/24/13 01:33 PM
dogdays Offline
dogdays  Offline
Look at your transmission crossmember. My '64Dog has a complicated crossmember that gets in the way of headers. My '71 donor truck has a simple one that headers don't run into.
I have a set of headers for bigblock Mopar into pickup, they are not expensive. I seem to remember some of them back in the day being for automatic only.
R.
Re: Sweptline BB guys [Re: dogdays] #1374912
01/24/13 02:16 PM
01/24/13 02:16 PM
Las Vegas
Las Vegas
Well I have no issue making a crossmember. Not that complicated of a job so not worried about that part. Part numbers for header woudl be a plus I have mid sump and rear suim pans here as well. Would love a pic of the motor mounts for a BB as I think we have a set here, at least that is what I was told they were.
Re: Sweptline BB guys [Re: Al_Alguire] #1374913
01/24/13 02:43 PM
01/24/13 02:43 PM
Las Vegas
Las Vegas
Here is an old picture of it
Re: Sweptline BB guys [Re: Al_Alguire] #1374914
01/24/13 04:04 PM
01/24/13 04:04 PM
dogdays Offline
dogdays  Offline
http://www.jegs.com/i/Flowtech/387/13504/10002/-1?parentProductId=#moreDetails
Hooker 5905?
http://www.summitracing.com/parts/hok-5810hkr/applications/make/dodge/model/d100-pickup?prefilter=1
Hedman makes them coated and uncoated
I think mine are either Dynomax or Blackjack.
Largest tube is i think 1 3/4.
R.
I just flat love those Lakester wheels.
Re: Sweptline BB guys [Re: dogdays] #1374915
01/24/13 04:51 PM
01/24/13 04:51 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Mine won't help you much
I made all custom stuff
Re: Sweptline BB guys [Re: bigdad] #1374916
01/24/13 07:51 PM
01/24/13 07:51 PM
Las Vegas
Las Vegas
Well mine looks a bit different currently as well. We were going to go R5P7 power with it but the deal fell through and I have all this BB stuff laying around. Was just curious what the sotck mount set up looked like. Not like we cannot fab up whatever we need.
For now it appears 511" BB Indy-1 heads and a TF for now This stuff was going to go into my 64 Savoy wagon which I will now be selling due to a new addition to the family
Re: Sweptline BB guys [Re: Al_Alguire] #1374917
01/24/13 08:16 PM
01/24/13 08:16 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Hard to see
Here it is
Re: Sweptline BB guys [Re: bigdad] #1374918
01/24/13 10:34 PM
01/24/13 10:34 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
I have a factory 383 in my 69 D200 and I have a couple extra sets of big block headers. Pretty easy to do the swap!
JB Rhinehart, Realist
A-Body's RULE!
Re: Sweptline BB guys [Re: Rhinodart] #1374919
01/24/13 10:50 PM
01/24/13 10:50 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
The '68 and older trucks have a cross member right in the way of all aftermarket big block headers. I cut the cross member out of my truck (it isn't on newer '69+ trucks so I didn't see it as being especially necessary).
You can see my build thread if you want over at Sweptline.org. There are lots of BB trucks over there.
http://www.sweptline.org/forums/viewtopic.php?f=34&t=21741
The joy with the headers starts around here:
http://www.sweptline.org/forums/viewtopic.php?f=34&t=21741&start=60#p161266
Re: Sweptline BB guys [Re: Al_Alguire] #1374920
01/24/13 11:45 PM
01/24/13 11:45 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I think Schumaker makes a new mount kit for it. The factory BB oil pan is front sump which of course is not the hot setup, I can't get to my truck right now to see if a rear sump off a later pickup will clear the axle but it seems to me it will on a stock height frontend anyway.
Sheldon
Re: Sweptline BB guys [Re: Al_Alguire] #1374921
01/25/13 12:58 AM
01/25/13 12:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
You're probably covered, but I have the old foot brake BB 727 out of the Mirada laying here doing nothing...
Re: Sweptline BB guys [Re: J_BODY] #1374922
01/25/13 03:44 AM
01/25/13 03:44 AM
Las Vegas
Las Vegas
J wish I knew that a couple months ago. Would not have dropped the money for a new one with all the goodies..Plus yours is already tailshaft tested and approved
Re: Sweptline BB guys [Re: Al_Alguire] #2615680
02/01/19 06:49 PM
02/01/19 06:49 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Al, 1st time I read your BB Sweptline post, so here's a pic of my 68 D100 (orig matching # 383 2bbl is in storage), with a 70 383 Magnum we just rebuilt. I got ceramic coated Hookers from Summit & they weren't even close to fitting, so Summit gave me nice Headman shorty ceramic headers. They're only 1 3/4" so probably not best for a stroker. I broke in the motor with the headers on, so that dulled the ceramic coating a little. Thick flanges & quality really nice for Headmans. We did have to modify the motor mounts, but that's no problem for you.
Re: Sweptline BB guys [Re: Triggerfish] #2616783
02/04/19 11:20 AM
02/04/19 11:20 AM
Eastern Ontario
shaker340 Offline
shaker340  Offline
Eastern Ontario
This is what I did for motor mounts to mount my 440.
No headers, they interfered with the steering shaft to rack and pinion.
Mike
2008 Challenger SRT8
1940 Chrysler Royal coupe
Re: Sweptline BB guys [Re: shaker340] #2616952
02/04/19 05:20 PM
02/04/19 05:20 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Mike
Very nice job Mike & engine bay looks awesome. You modified your mounts almost like we did on the D100. Also hope my Hemi Orange W100's engine bay looks as nice as yours! Only headers I could use on it's 383 were cheap Flowtechs that we had to "dimple" quite a bit.
