Re: BG Speed Demon carb ok for racing?
[Re: Jonnyj00]
#1374702
01/23/13 08:10 PM
01/23/13 08:10 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
With all the bad reputation stories about Demon carbs I would stay away unless it's a deal you can't refuse Holley 750 DP carbs are pretty easy to find used Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Jonnyj00]
#1374705
01/23/13 09:50 PM
01/23/13 09:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
There is a reason he is selling it.... most of the times it was because BG stuff was bad... usually a quality control issue... I dont buy BG stuff due to that
[Re: Jonnyj00]
#1374706
01/24/13 01:25 PM
01/24/13 01:25 PM
Posts: 5,080 organ
maximum entropy
organ
i have a mighty demon on mine. it's a good carb, once you work out the kinks (it only took a few years). my pump squirter holes stripped out, and i found a supplier in florida who had the appropriate inserts (the only supplier in the country, far as i know). like all bg carbs, it was FULL of metal. i've seen some with cross threaded jets, throttle blades installed upside down, it seems their problems are usually assembly related. i've done a bunch of them, from speed demons, all the way up to race demon rs. they always have metal in them, and some kind of assembly error.
[Re: Jonnyj00]
#1374708
01/24/13 01:51 PM
01/24/13 01:51 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I have heard all of the horror stories also about BG. I have a 1090 & a 1290 King Demons & have never had any problems with either one. Now that Holley owns BG most everything is available for them again.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Jonnyj00]
#1374709
01/24/13 02:08 PM
01/24/13 02:08 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Sounds like I'll be passing on that one. Thanks guys.
I have a 750 3310 vacuum secondary holley that they sell a conversion kit for at speedway for like 130 is this a reasonable option? I'm just a broke college student or I would just go by a new carb...
Conversion kit for a rear metering block? If so, you can piece that together for much less than 130. Probably 30-40 bucks.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
