Dynamic compression calc
#1374627
01/23/13 04:57 PM
01/23/13 04:57 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Would anybody care to help me figure out my dynamic compression and cranking psi? Ive figured it with different calculators and get very different answers. 297 at .015 @.050 Int open 24 btdc close 56 abdc Ex open 63 bbdc close 23 atdc I havent degreed the cam, but have notes the previous owner wrote down. Maybe they will help.. Intake lobe .133 @ tdc .394 @ 107 atdc 0 @ tdc 24 btdc @.050 15 atdc @ .200 44 atdc @ .300 168 atdc@ .300 196 atdc@ .200 238 atdc @.050 Static is 11.4. 4.375 bore, 3.915 stroke, 6.385 rod. Thanks
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Dynamic compression calc
[Re: MR_P_BODY]
#1374629
01/23/13 05:42 PM
01/23/13 05:42 PM
Von
NE Oklahoma
Mr. P,
I used that calc and came up with 9.46. If I use the KB calc I get 8.68??
[Re: Von]
#1374630
01/23/13 06:02 PM
01/23/13 06:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Mr. P,
I talked to one of the engine builders on here and for my engine he came up with a number very close to the wallace so I tend to use it
[Re: Von]
#1374631
01/23/13 06:26 PM
01/23/13 06:26 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
@.050
duration @50 int 260 degrees ex 266 degrees LSA 108 degrees ICL 106 degrees
If the advertised intake duration is 297, the exhaust duration must be 303 degrees
advertised Int open 42.5 btdc close 74.5 abdc Ex open 81.5 bbdc close 41.5 atdc
Using the wallace calculator and IVC 74.5 degrees atdc gives a dynamic compression ratio of 8.36:1.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: Mick70RR]
#1374632
01/23/13 07:23 PM
01/23/13 07:23 PM
Von
NE Oklahoma
[quoteUsing the wallace calculator and IVC 74.5 degrees atdc gives a dynamic compression ratio of 8.36:1.
8.36 should be safe with pump 91, correct? Quench is .040, alum heads.
Thanks!!!!!
[Re: Von]
#1374634
01/23/13 07:35 PM
01/23/13 07:35 PM
MR_P_BODY
Thanks!!!!!
Yes... did you get a cranking pressure
[Re: Dodgem]
#1374638
01/24/13 09:40 PM
01/24/13 09:40 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I like this one plug in your specs and @.050 (56 ABDC??) numbers 0 for boost http://www.rbracing-rsr.com/comprAdvHD.htm
9.5 ish Dynamic cranking 195 ish on the edge of 91 93 should be fine assuming aluminum heads!
This is the one I was referring too. It is the same calculator as the Wallace, but Wallace says put in seat timing.
[Re: Von]
#1374639
01/24/13 10:56 PM
01/24/13 10:56 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
regardless of what the calcs say....IMO, 11.4cr, that cam, and 91 octane is going to be "iffY'....at best. especially in Oklahoma summer heat.
[Re: BSB67]
#1374640
01/26/13 12:06 PM
01/26/13 12:06 PM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
IMO it's natural to use the seat timing, since that's when you actually start building pressure.
But, you have to carefully check what input data the calculator is expecting, wrong data in and the output will be incorrect.
I have made my own calculator, and cannot comment on different web-based calculators.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
[Re: Swedcharger67]
#1374641
01/27/13 10:24 AM
01/27/13 10:24 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
What should the DCR and cranking compression be for the different grades of today's gasoline (87, 89, 91 octane)?
This is the land of the free
because of the brave
