Re: Positive ground electical question
[Re: 4spd69gtx]
#1374601
01/23/13 06:07 PM
01/23/13 06:07 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
Im a Firefighter and we have an antique firetruck with 12V positive ground. It is a 1956 Ward LaFrance with a Mopar 392 Hemi of the same vintage. It still has its original ignition system and runs like a dead cat. We are thinking about converting to electronic ignition but with the positive ground we dont know how to approach this.. Suggestions on a new ignition system would be appreciated. Thanks
Those trucks should have had a either, depending on which part of the year it was produced, 331 or a 354 C.I. industrial Chrysler motor in them, not a Desoto or Dodge motor. If so it will have 1/2 valve stems, solid liters with adjustable rocker arms, super low compression, a carb. with a built in governor and some other small changes from the car motors Probally around 220 HP, not a hot rod in a heavy truck
[Re: 4spd69gtx]
#1374602
01/23/13 10:20 PM
01/23/13 10:20 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Another approach, maybe more complicated but save some issues in the long run, is to convert it to negative ground. The things polarity sensitive would be the generator/regulator, the radio (two way and AM if it had one), and the starter/solenoid. Lights do not care, the Federal Q will run backwards but it would sound the same as frontwards and the revolving lights may have to be changed. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 1_WILD_RT]
#1374605
01/24/13 12:17 AM
01/24/13 12:17 AM
denfireguy
Colorado
Older Motorolas had polarity plugs. That was easier than dealing with how to ground the antenna and coax without shorting out the radio.
Generator will go both ways, thats why you need to polarize it.. If it has a two way it' probably a Motorola & if thats the case it's probably built as a negative ground & the mount is isolated.... Starter & solenoid don't care unless there a clamping diode & since clamping diodes didn't show up till the 80's.........
[Re: 1_WILD_RT]
#1374606
01/27/13 02:22 PM
01/27/13 02:22 PM
Posts: 606 Montana
Yancy Derringer
Montana
.............. convert it to negative ground. The things polarity sensitive would be the generator/regulator, the radio (two way and AM if it had one), and the starter/solenoid. Lights do not care, the Federal Q will run backwards but it would sound the same as frontwards and the revolving lights may have to be changed. Craig
The last is largely correct
Lights, solenoids, motors "don't care." Anything you have that's electronic WILL. The caveat to re--polarizing the generator is the CONTACTS IN THE REGULATOR. Some regulators (replacement aftermarket) are designed for either polarity to reduce inventory. Some OEM regulators were built with different contact materials, and would burn out if reversed.
If you have a positive ground alternator, that will have to be reworked/ replaced, depending.
The thing is, I'm old enough to have "been there." I've ridden in, driven, tuned up, been around cars for a very long time, and back then ALL of them had breaker points ignition. I'm sure you don't drive that thing very far, are you REALLY going to gain anything? There is no reason on earth that a PROPERLY gone through distributor won't work just fine with breaker points.
How often is the truck run?
