Piston ring recomendation? #1374496
01/23/13 01:19 AM
01/23/13 01:19 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Freshing up the 500" stroked 400 after the cylinder head issue, and I am curious if changing the file fit Total seal CR9190-130 rings to a different type or brand would make much difference. The engine is 12.4:1 compression and max RPM is 7,000.
Anyone use the M9190-130 MaxSeal gapless top ring set?
Re: Piston ring recomendation? [Re: 451Mopar] #1374497
01/24/13 02:55 AM
01/24/13 02:55 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Anyone using gapless rings? Are they worth the extra $100+ over the standard rings?
Re: Piston ring recomendation? [Re: 451Mopar] #1374498
01/24/13 04:55 AM
01/24/13 04:55 AM
SoCal
Brian Hafliger Offline
SoCal
If 5 or 6 HP is worth over 100.00 to ya then go for it!
Brian Hafliger
Re: Piston ring recomendation? [Re: Brian Hafliger] #1374499
01/24/13 10:24 AM
01/24/13 10:24 AM
Gapless were invented for dirt cars that ate rings- They do offer impressive leak down test results but on the dyno I have never seen the HP gain. Correctly filed rings with a ductile top ring is the standard that has won most races.
For whatever reason the leak down that looks fantastic does not seem to convert to more power--because of ring flutter at higher RPM or what I don't know but gapless rings are not magic or they would be in every engine built
You have to remember that KB did back to back dyno test while working on the proper gap for their hyper pistons and the top gap had to exceed something like .055 before they could see a HP drop--Now..thats their tale but many shops agree, keep rings from butting and make sure fresh cylinders are clean and you have done all that you can in that dept.
Re: Piston ring recomendation? [Re: 451Mopar] #1374500
01/24/13 03:42 PM
01/24/13 03:42 PM
Total Seal does not, the last time I talked to them about race engine ring packages, recommend there gapless rings for drag racing I like and use the Speed Pro file to fit moly top, cast second and standard tension oil rings on motors with no vacume pump Hastings( American Hammer) makes some nice race ring packages also
Re: Piston ring recomendation? [Re: Cab_Burge] #1374501
01/24/13 08:36 PM
01/24/13 08:36 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I am getting away from all the "trick of the week" ring set-ups. I have always used the old 1/16-1/16-3/16 Speed Pro rings as Cab has mentioned,,,moly/cast/standard tension oil ring...I think they are the most fail-safe ring set going. I have tried other sets and had some problems of one sort or another enough times. I am not looking for 3-4 HP.
If you like drag racing, support your local track.
Re: Piston ring recomendation? [Re: Cab_Burge] #1374502
01/25/13 04:37 AM
01/25/13 04:37 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Thanks guys
I did some web searching and it seems most people think they are no better than the standard moly rings.
I may just reuse the rings I have. Only a few dozen 1/4 mile rounds and maybe 200 street miles on the engine, but somehow I managed to bend an oil ring (I think moving parts around
The bearings looked good too, but I am thinking of having the pistons cut for deeper valve reliefs and re-balance the engine.
Re: Piston ring recomendation? [Re: 451Mopar] #1374503
01/25/13 01:15 PM
01/25/13 01:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d go moly top, napier second and standard tension oil unless you run a vac pump. I run this set up w/out a v-pump and med tension rings and have just a bit of blow-by so I may end up installing a pump just to help w/leaks and ad maybe controll blow-by a bit...........
Re: Piston ring recomendation? [Re: 451Mopar] #1374504
01/25/13 01:41 PM
01/25/13 01:41 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
IIRC that's what I ran in the last build of my 452. I'm not sure whether I could quantify any improvements over a more conventional ring package w/o an exacting back-to-back test, although I like them in theory.
However, this time I went back to a conventional top ring, switched to a Napier 2nd, and lowered the oil tension from 23# to 18#. Since the engine isn't running, yet, all I can say is this "should" provide decent oil control while offering some reduction in friction compared to the previous ring pack.
Re: Piston ring recomendation? [Re: Thumperdart] #1374505
01/25/13 03:11 PM
01/25/13 03:11 PM
Delray beach, Florida
P
Performance Only Offline
P
On a true street car i prefer to stay away from the napier 2nd ring. During normal street driving they can actually scrape too much oil off the cylinder walls which causes more wear. Racing engines can utilize the napier ring more effectively because they see continued high rpm which throws additional oil up on the cylinder walls. They're also very effective for engines using power adders where even small amounts of oil getting past the rings and into the chambers can wreak havoc.
machine shop owner and engine builder
Re: Piston ring recomendation? [Re: Performance Only] #1374506
01/25/13 03:28 PM
01/25/13 03:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My decision on the napier second came from a few racers(Nascar included)that stated great things ESPECIALLY on street cars and apparently lots of new cars both import and domestic(Corvetts)run em 100`s of thousands of miles w/great results........either way.
Re: Piston ring recomendation? [Re: 451Mopar] #1374507
01/26/13 10:33 AM
01/26/13 10:33 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Thanks guys
You can save some $$ and buy a set of such rings for one piston from 440Source (and maybe from others!) I did, after breaking a 2. ring! My
Re: Piston ring recomendation? [Re: Oyvind Mopar] #1374508
01/26/13 07:26 PM
01/26/13 07:26 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Why don't you buy some .155 radial wall rings...... use the hastings oil rings...........
