Re: Caltrac Mono Leafs & Sliders [Re: WHITEDART] #1374417
01/24/13 12:36 AM
01/24/13 12:36 AM
Toronto
mshred Offline
mshred  Offline
Toronto
I would say more important than trying to lube the sealed bearings.. is to keep it clean the rubber and rocks will build up .. one of the things that I like the most about this set up is less side to side movement..john calvert will tell you for a trans brake set up run a bunch of shock so you wont see much movement at the slider. my set up will move less than 1/2 inch on a pass
as in a stiff shock setting? What shocks do you run? what setting? radial?
Re: Caltrac Mono Leafs & Sliders [Re: mshred] #1374418
01/24/13 12:36 AM
01/24/13 12:36 AM
Ohio
Todd Offline
Todd  Offline
Ohio
I use Castle Endura Lube. Its a light penetrating grease doesn't leave such a mess like the white stuff does. Sorry Mr P.
Re: Caltrac Mono Leafs & Sliders [Re: mshred] #1374419
01/24/13 12:42 AM
01/24/13 12:42 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
QA 1 set on 8 or 10 for the break 2 or 3 for foot break this is on a 10.5 slicks hooks in a car wash 10.00 1.32 60ft
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Caltrac Mono Leafs & Sliders [Re: WHITEDART] #1374420
01/24/13 01:25 AM
01/24/13 01:25 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Now you guys got me thinking about another mod to hopefully go even quicker.......... I can weld those in myself w/the help of my room mate..........
Re: Caltrac Mono Leafs & Sliders [Re: Thumperdart] #1374421
01/24/13 02:15 AM
01/24/13 02:15 AM
Renton Washington
Triple Threat Offline
Renton Washington
Question for anyone:
Do you install them so the slider is in the middle of its travel at rest/ ride height or slightly one way or another? Pictures would be nice.
EDIT: found this http://www.afcoracing.com/tech_pages/leaf.shtml
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Caltrac Mono Leafs & Sliders [Re: Triple Threat] #1374422
01/24/13 08:41 AM
01/24/13 08:41 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Here is post I had a while back that went over a lot of your questions.
In this pic with the susupesion hanging all the way down I have 3/4" until they bottom out on the forward side. At ride height their an inch past center.
https://board.moparts.org/ubbthreads/favl...amp;postmarker=
Re: Caltrac Mono Leafs & Sliders [Re: Todd] #1374423
01/24/13 11:14 PM
01/24/13 11:14 PM
Stockholm, Sweden
TomsCharger70 Offline
Stockholm, Sweden
This is a good and interesting thread. Im planing on going the Cal-Tracks setup route.
Question: I want to keep the more or less standard ride hight of my car. When using sliders, do you buy the "standard" or +1 arch leafspring???
Thanks!
/Tom
Re: Caltrac Mono Leafs & Sliders [Re: TomsCharger70] #1374424
01/24/13 11:55 PM
01/24/13 11:55 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Thanks!i I thank +1 will be safe keep in mined john calvert said lowering block are ok with this set up. my car seems to 60ft better with a 1" lowering block.. maybe more leverage
/Tom
Re: Caltrac Mono Leafs & Sliders [Re: Triple Threat] #1374425
01/25/13 01:15 AM
01/25/13 01:15 AM
Toronto
mshred Offline
mshred  Offline
Toronto
I tried to set my sliders so that at rest with all the weight on the car the rear eye is about 2/3rd's of the way back...Reasoning for this is because the spring eye will travel forwards alot more then it will travel backwards, not to mention when I checked the travel it only made sense to put the eye there otherwise it would have bottomed out on the front with any real sort of spring seperation
As for the slider angle on Afco's tech pages, I was told that is more for stock car/roundy round stuff, and that for drag racing its not really nescessary
Re: Caltrac Mono Leafs & Sliders [Re: mshred] #1374426
01/25/13 02:58 AM
01/25/13 02:58 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Caltrac mono-leafs and leaf spring
sliders on my 71 Demon.
Not done building the car yet.
Re: Caltrac Mono Leafs & Sliders [Re: demon440] #1374427
01/25/13 11:44 AM
01/25/13 11:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
See how far the vertical walls hang over the frame
rail... thats why I added metal to both sides(the
vertical walls are the load carrying points) and I
felt it would be easy to have the walls bow upward
being they are hanging in space.... JMO
Re: Caltrac Mono Leafs & Sliders [Re: MR_P_BODY] #1374428
01/25/13 12:21 PM
01/25/13 12:21 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I am going to follow this thread closely as I am still working out the rear suspension on my Ramcharger. I already bought the sliders, but in my case there is almost no clearance between the stock frame rail and the axle tube (axle on top of spring)and I will have to build a spacer between the frame and the sliders to get the clearance
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Caltrac Mono Leafs & Sliders [Re: MR_P_BODY] #1374429
01/25/13 12:37 PM
01/25/13 12:37 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Wouldn't it make sense to put some bracing there back to the frame? Just weld it from the corner up.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Caltrac Mono Leafs & Sliders [Re: Todd] #1374430
01/25/13 12:40 PM
01/25/13 12:40 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Past center forwards or rearwards?
Re: Caltrac Mono Leafs & Sliders [Re: 1967dartgt] #1374431
01/25/13 01:05 PM
01/25/13 01:05 PM
Ohio
Todd Offline
Todd  Offline
Ohio
At ride height, just past center around 3/4 to an inch twords the rear.
Re: Caltrac Mono Leafs & Sliders [Re: Todd] #1374432
01/25/13 09:18 PM
01/25/13 09:18 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I have run the sliders w/ caltrac's the last 2 seasons, my car runs 10.20's to 10.50's pretty much hooks anywhere on a 10.5 slick. It ain't the fastest but very consistent.
Re: Caltrac Mono Leafs & Sliders [Re: nss guy] #1374433
01/25/13 09:22 PM
01/25/13 09:22 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
sliders yes they have gussets
Bob's Profab did the install
Re: Caltrac Mono Leafs & Sliders [Re: mcduff] #1374434
01/26/13 02:48 AM
01/26/13 02:48 AM
ca
brownout Offline
brownout  Offline
ca
good thread so far. Now is anyone on here running an anti roll with a caltrac setup?
Cody
