Re: Caltrac Mono Leafs & Sliders
[Re: WHITEDART]
#1374417
01/24/13 12:36 AM
01/24/13 12:36 AM
Posts: 3,415 Toronto
mshred
Toronto
I would say more important than trying to lube the sealed bearings.. is to keep it clean the rubber and rocks will build up .. one of the things that I like the most about this set up is less side to side movement..john calvert will tell you for a trans brake set up run a bunch of shock so you wont see much movement at the slider. my set up will move less than 1/2 inch on a pass
as in a stiff shock setting? What shocks do you run? what setting? radial?
[Re: mshred]
#1374419
01/24/13 12:42 AM
01/24/13 12:42 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
QA 1 set on 8 or 10 for the break 2 or 3 for foot break this is on a 10.5 slicks hooks in a car wash 10.00 1.32 60ft
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Triple Threat]
#1374422
01/24/13 08:41 AM
01/24/13 08:41 AM
Posts: 1,377 Ohio
Todd
Ohio
Here is post I had a while back that went over a lot of your questions. In this pic with the susupesion hanging all the way down I have 3/4" until they bottom out on the forward side. At ride height their an inch past center. https://board.moparts.org/ubbthreads/favl...amp;postmarker=
[Re: Todd]
#1374423
01/24/13 11:14 PM
01/24/13 11:14 PM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
This is a good and interesting thread. Im planing on going the Cal-Tracks setup route. Question: I want to keep the more or less standard ride hight of my car. When using sliders, do you buy the "standard" or +1 arch leafspring??? Thanks! /Tom
[Re: Triple Threat]
#1374425
01/25/13 01:15 AM
01/25/13 01:15 AM
mshred
Toronto
Question for anyone:
Do you install them so the slider is in the middle of its travel at rest/ ride height or slightly one way or another? Pictures would be nice.
EDIT: found this http://www.afcoracing.com/tech_pages/leaf.shtml
I tried to set my sliders so that at rest with all the weight on the car the rear eye is about 2/3rd's of the way back...Reasoning for this is because the spring eye will travel forwards alot more then it will travel backwards, not to mention when I checked the travel it only made sense to put the eye there otherwise it would have bottomed out on the front with any real sort of spring seperation
As for the slider angle on Afco's tech pages, I was told that is more for stock car/roundy round stuff, and that for drag racing its not really nescessary
[Re: demon440]
#1374427
01/25/13 11:44 AM
01/25/13 11:44 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Caltrac mono-leafs and leaf spring sliders on my 71 Demon. Not done building the car yet.
See how far the vertical walls hang over the frame rail... thats why I added metal to both sides(the vertical walls are the load carrying points) and I felt it would be easy to have the walls bow upward being they are hanging in space.... JMO
[Re: MR_P_BODY]
#1374428
01/25/13 12:21 PM
01/25/13 12:21 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I am going to follow this thread closely as I am still working out the rear suspension on my Ramcharger. I already bought the sliders, but in my case there is almost no clearance between the stock frame rail and the axle tube (axle on top of spring)and I will have to build a spacer between the frame and the sliders to get the clearance
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: nss guy]
#1374433
01/25/13 09:22 PM
01/25/13 09:22 PM
Posts: 1,442 central ohio
nss guy
central ohio
sliders yes they have gussets Bob's Profab did the install
