hi all -
i have the original system in my car (single pot master cylinder, 4 way drum) and want to upgrade to a dual master cylinder
Questions:
- are the 67 MC's available still today from a parts store? - does anyone have a part number?
- is there a kit for the brake lines that would be necessary just to do the MC upgrade (assuming here that most of the brake lines can stay put)?
- if i am doing this, should i change out all the brake lines? - if yes, is there a stock style i should go for or will it not matter once it is no longer original and just get stainless steel?
- any other tips/tricks?
thanks
