Re: Here we go again !
[Re: VernMotor]
#1373984
01/22/13 12:47 AM
01/22/13 12:47 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Thats strange that they are all pushing out. It would seem that they may be all on the tight side. But , I wouldnt figure that they would all want to push out. Are they pushing out all the Same direction?? as in All towards the back of the engine or the front. Or just all random directions both front and back?? If its direction one way , that may indicate that the crank is not parallel, perpendiculularly with the cylinders maybe. Just thinking out loud here, ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Sport440]
#1373985
01/22/13 08:51 AM
01/22/13 08:51 AM
Posts: 1,629 pa
572charger
pa
did u pin fit the rods ? all brand new rods need pin fitted to the piston pins u are useing , even my 1600..00 olivers needed done i put 9 tenths to a little over 1 thou depending on application ,no2 and blown/ turbo need more because they will gauld the pin to the bushing easy !!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: VernMotor]
#1373988
01/22/13 11:29 AM
01/22/13 11:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Jamie these are full floater correct... where are the locks at... did they push out EDIT it can really be only 1 thing(my opinion) that the press fit of the bushing into the rod isnt tight enough and for some reason the pin to the bushing has more friction then the bushing to rod... the pin must have been too tight on the fit ![](/ubbthreads/images/graemlins/wave.gif)
[Re: VernMotor]
#1373991
01/22/13 07:13 PM
01/22/13 07:13 PM
Posts: 2,091 Delray beach, Florida
Performance Only
Could you post some good clear pictures of the front and back of the rod bearings as well as the big end bore (rod half, not cap half) of 2 or 3 connecting rods please.
machine shop owner and engine builder
[Re: FastmOp]
#1373993
01/22/13 08:07 PM
01/22/13 08:07 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Now you can't say a bad word about 440source ever again ![](/ubbthreads/images/graemlins/Twocents.gif)
I'm betting the block was machined wrong but it is hard to say. Did the pins get oil on assembly?
Yes I put the motor together and yes they had lots oil on them. motor has 250-300 runs on it. maybe more. I got some other 440 source parts I can complain about..But I can't blame the rods now.
[Re: Performance Only]
#1373994
01/22/13 08:08 PM
01/22/13 08:08 PM
VernMotor
Mt.Vernon ,Ohio
Yes I will take some pics for you dan ![](/ubbthreads/images/graemlins/smile.gif)
[Re: B G Racing]
#1373995
01/22/13 08:12 PM
01/22/13 08:12 PM
VernMotor
Mt.Vernon ,Ohio
The bushing need to be a interference fit to the rod either by heating and expanding the rod or freezing the bushing or both.Then fitting the bushing for the pin.To only press fit the bushing in the rod can cause the the bushing to come out.
These was new eagle rods. the bushings was already in them, But I did have the same shop put new bushings in the 440 S rods. Have not use them yet will have to have them checked out now ![](/ubbthreads/images/graemlins/down.gif)
[Re: B G Racing]
#1373997
01/22/13 08:34 PM
01/22/13 08:34 PM
VernMotor
Mt.Vernon ,Ohio
Another thing you can look at is do the rod bearing showing wear at the crank side.If they were riding on the crank radius it can angle load the pin causing the bushing to galled.
I going to put up some pics here in a min. But the rod bearing look like new so do the piston.
[Re: Dan Brewer]
#1374000
01/22/13 09:53 PM
01/22/13 09:53 PM
VernMotor
Mt.Vernon ,Ohio
Why no spiral locks? I would say thats your problem with the pins coming out.
These pistons do not use spiral locks. pins are not coming out, not all piston use spiral lock ![](/ubbthreads/images/graemlins/smile.gif)
