I have a 72 dart with 10 inch front brakes small bolt pattern and trying to find out what the difference is between the 10 inch and 9 inch control arms, spindles, and the hubs for the drums. The problem im having is that i need hubs mine wont accept the new bearing racesthe are loose and worn out. I want to use the drum setup because i want to keep it original
and need to know what my options are as far as hubs and upper control arms are they the same as 9 inch?? I believe the hubs are different???? Any help will be greatly appreciated!!
