Mopar Newb question #1373727
01/21/13 06:14 PM
01/21/13 06:14 PM
Oklahoma
delta10 Offline OP
delta10  Offline OP
Oklahoma
Hey, guys I just joined the forum. Need a little help. Building a 440 small block from ground up. I see there are a at least two options on a timing chain cover for the LA family. One at around $149 and one around $489. What is the difference. If it matters I am going to be running a Billet Spec front runner system.
Thanks Guys.
Re: Mopar Newb question [Re: delta10] #1373728
01/21/13 06:20 PM
01/21/13 06:20 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Links to said parts?
What block are you going to use? 440" in a small block is no mild build.
What's your HP goals, usage, etc
What heads are you going to run?
**Photobucket sucks**
Re: Mopar Newb question [Re: delta10] #1373729
01/21/13 06:27 PM
01/21/13 06:27 PM
Welcome here . Yes more info on the 2 selections you are considering. Though I wouldn't pay 489 for a timing cover unless it was required for my app & if it was I think I'd go a different route on the parts that were making it a required item.
