Re: Video clip of some mods for the Track
[Re: firefighter3931]
#1373267
01/26/13 09:52 AM
01/26/13 09:52 AM
Posts: 2,926 A shed in England
Tig
A shed in England
Wow! and I thought my car was heavy! Good stuff
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1373268
01/27/13 05:37 AM
01/27/13 05:37 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Thanks guys...I do have to thank you all! I have gathered much of my info, knowledge and parts of the combo from all of you guys here. Moparts is the best!!!
[Re: Chargerfan68]
#1373270
01/27/13 09:34 AM
01/27/13 09:34 AM
Posts: 2,128 sweden
sshemi
sweden
Whats your 1/8 mile et? How where the front shocks set? What rear tires? Stiff sidewall?
Sorry for asking this much but this summer i really want my 4 speed cuda to hook.
[Re: sshemi]
#1373272
01/27/13 11:01 PM
01/27/13 11:01 PM
Chargerfan68
New York, USA
My 1/8 mile best was 99 MPH and the front shocks are set to max easy rebound and stiff compression. Rear slicks are M/T Drag slicks 28-11.5 15 inch and I run tubes. Maybe this is why it acts as a slightly stiffer sidwall slick, and helps me out on the stick car?
I also should note that I also purchased Caltrac monoleaf spring with the bars when I installed them. He tailors the spring to each car based on body style, weight, trans type, etc..
I know everyone has their own experiences, but SS springs just plain didn't work on my car. I previously installed brand new SS springs from Mopar performance 3800 pound auto springs. The first few times I did practice launches with the car with them, the springs wrapped up so bad, the rear axle moved forward and the tires clipped into the front of the wheel wells cutting the tires up (Brand new M/t et street drag radials). I also had the front segments of the springs clamped very tightly in 2 spots each. The springs are in my garage now in the shape of a slight "S".
I went to Caltracs, and What a difference! Then again..this is on my car. Each car might act differently.
I hope this helps.
