Rockwell hardness numbers for rods and crankshaft #1373074
01/20/13 11:11 PM
01/20/13 11:11 PM
Cab_Burge Offline OP
I'm hoping someone on here will know a good range of rockwell hardness numbers for H and I beam steel rods and the same for a decent forged steel crankshaft If I'm remembering correctly the first batch of Ohio Forged Steel Crankshaft CO. I bought where between 22 and 25C rockwell The crank grinders and machine shop I used at that time in SO CA thought that was to soft, I didn't have those reheat treated I have one of those cranks in my 505 C.I. bracket motor and found out recently there is a heat treating company near by, so I thought I would ask on here first and see about having that crankshaft reheat treated next winter, if it really needs it One other question, what do you guys pay for heat treating a B-RB forged steel stroker crank and for a set of 8 rods?
Re: Rockwell hardness numbers for rods and crankshaft [Re: Cab_Burge] #1373075
01/20/13 11:33 PM
01/20/13 11:33 PM
parma,ohio
66littlebigmopar Offline
parma,ohio
I'm not 100% sure but won't heating treating tweak the crank and rods reqiuring then to get straightened. I know when parts at work get heat treated at work the next set is straightening, though there not automotive parts they are carbon steel parts. I know tooling is about 45-50 rockwell.
Re: Rockwell hardness numbers for rods and crankshaft [Re: 66littlebigmopar] #1373076
01/20/13 11:44 PM
01/20/13 11:44 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
That Rockwell range sounds about right for a 4140/4340 steel. I wouldn't mess with the heat treating as previously mentioned, maybe get it nitrided for a surface hardening, but I wouldn't do a full on heat treating at this point
Re: Rockwell hardness numbers for rods and crankshaft [Re: WO23Coronet] #1373077
01/21/13 12:06 AM
01/21/13 12:06 AM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Re: Rockwell hardness numbers for rods and crankshaft [Re: Cab_Burge] #1373078
01/21/13 12:10 AM
01/21/13 12:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
22-25 rockwell C is like butter....a file is 62 Rc
and I would think good quality steel is 45-50 Rc...
you dont want them too hard but no where near 25Rc
EDIT
Axles range from 57-59 Rc
Re: Rockwell hardness numbers for rods and crankshaft [Re: MR_P_BODY] #1373079
01/21/13 01:11 AM
01/21/13 01:11 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I seem to recall 38 rockwell for the SBC " pink " rods , so that does seem soft.
Rather than heating , I'd look at a Cryro treatment.
Much less distortion of the part and more consistent grain structure afterwards.
I think because the temperature control is tighter with freezing as opposed to heat.
Tooling rockwell numbers depend on material and end use , with forming tools typically using lower numbers and different types of steel than stamping or cutting tooling.
Powdered metals skew the curve a bit too , but their prices kept us from using a lot if it when I was in that line of work.
But crankshafts are not through hardened like most tools......generally a case hardening that is usually less than .030 deep......often much less.
Re: Rockwell hardness numbers for rods and crankshaft [Re: MR_P_BODY] #1373080
01/21/13 02:43 AM
01/21/13 02:43 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
EDIT
Yeah and files snap like twigs when you put any kind of load on them as well, not exactly what u want for a crank. U can take 4140/4340 to the low mid 40's for RC with full heat treating but that's where u want it for making vice jaws, tooling (not cutting tools), and for something thay needs high wear resistance. The higher u go for RC, you lose toughness and maleability, which a crank needs. Go to most any machine shop and ask for a shaft/ bushing whatever to be made and it needs to put up with alot of abuse (loader bucket pins/bushings etc) and they go right to there rack of 4340 and use that in its non heat treated form, which is in the mid 20's for RC.
With all the torsional/longditudal forces on a crank I don't think u would want it very hard, although my experience is from the general maching end of it so I could be wrong
Re: Rockwell hardness numbers for rods and crankshaft [Re: WO23Coronet] #1373081
01/21/13 02:53 AM
01/21/13 02:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I used the file as a reference point so he could
get a idea... thats all... if you want the right numbers
its wise to call the manufacturer of the better
cranks and rods... on the axles I pulled the prints
at work(Chrylser) so I could get the RC range so
I could get a set of axles cut and hardened to the
upper end of the spec
