Re: block porn it's here
[Re: rickraw]
#1372983
01/22/13 11:21 PM
01/22/13 11:21 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
thanks I have been on kents call list before .. might be some time . but new casting looks nice I have the same one..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#1372987
01/23/13 05:19 PM
01/23/13 05:19 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
thats awesome. if you wanted, could that block be modified for oiling through the heads to use LA heads? amazingly nice block, but i do like LA heads and shaft mounted rockers.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopardude318]
#1372990
01/23/13 10:44 PM
01/23/13 10:44 PM
WHITEDART
bean town ....Ca
rocker oiling.... it would be a long way to drill.. maybe buy a very good shop ..but out side oil lines would work fine
[Re: rowin4]
#1372992
01/24/13 05:36 PM
01/24/13 05:36 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Sure is a lot of core shift of misplaced lugs for the lifter side extra head studs. The outside edge lines up great. The inside if pretty far off.
That rear seal is the rear main and is way superior to the stock style. The 360 rear pan seal is better to. smaller lighter cap.
[Re: Leon441]
#1372993
01/24/13 06:23 PM
01/24/13 06:23 PM
Posts: 437 south central pa
bdaz smblk
south central pa
I heard the cam tunnels were a problem too.I was just going to buy one for my new build until i heard there was still lots of problems that haven't been corrected.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: bdaz smblk]
#1372994
01/24/13 06:53 PM
01/24/13 06:53 PM
Leon441
Lynchburg, VA
I had several of those spacers to put 340 pans on 360 caps. Nothing specail. It is cast aluminum and you silicone it into the groove in the cap where the seal usually would go. Very easy to make with 3/8 aluminum plate.
Leon
[Re: Leon441]
#1372995
01/24/13 06:57 PM
01/24/13 06:57 PM
Posts: 3,395 Pa
Hot 340
Pa
That is cast to accomodate p7 studs. It's not shifted when drilled for them..(so I have been told)
