440 build #1372895
01/20/13 07:45 PM
01/20/13 07:45 PM
ohio
geol Offline OP
geol  Offline OP
ohio
I am installing a 440 into a 65 Dodge Coronet.The car was originally a 273 with power steering.My first question is can I use the power steering pump from the 273? The 440 is from a 1977 truck.The water pump is a Mopar P4286899.The power steering pump bracket from the 273 won't adapt to this pump without modification.I will also need both pulleys and an alternator and bracket.Where do I start and where will I find the right parts?
Re: 440 build [Re: geol] #1372896
01/20/13 07:57 PM
01/20/13 07:57 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
http://bouchillonperformance.com/
These guys are the best for what you need.
Re: 440 build [Re: moparpollack] #1372897
01/20/13 10:20 PM
01/20/13 10:20 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
www.forbbodiesonly.com
Go to the 62-65 section
This is the land of the free because of the brave
Re: 440 build [Re: rbstroker] #1372898
01/20/13 10:37 PM
01/20/13 10:37 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I've used pulleys & brackets for a '69 GTX non-AC application for that on my '63 swap. Worked perfectly.
