Re: Denso 60 amp wiring....................
[Re: Thumperdart]
#1372824
01/20/13 05:14 PM
01/20/13 05:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Here is the simple version of the wiring but you can figure it out from this
[Re: Thumperdart]
#1372827
01/20/13 06:35 PM
01/20/13 06:35 PM
MR_P_BODY
Found it...........so I don`t use the lamp wire and the ign is direct 12v so is the sense wire keyed 12?
My Denso is 2 field wires... 1 is 12v the other is keyed 12v... one is the sense wire the other is the trigger wire(which turns on and off to tell the alt what to do)... mine doesnt have the third wire which is the idiot light
[Re: Thumperdart]
#1372828
01/20/13 07:28 PM
01/20/13 07:28 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Dom that ? depends on which alt you have the pic Mr-P showed is for the mopar style one (remote reg), not the toyota
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#1372831
01/20/13 10:22 PM
01/20/13 10:22 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Andy sells the plug now too Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Thumperdart]
#1372834
01/21/13 10:30 PM
01/21/13 10:30 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
When I was doing the swap to the toyo-denso I read somewhere that you could do something like that, although they took it apart and did it internally, IIRC.
The whole point of running the sense wire to the battery is that it will tell the alternator what the voltage is after all of the power draws such as your ignition, lights, electronic accessories, etc.
Not sure what your plans are for your car. On a drag car it may not make much difference if you are hooking it to a battery charger between runs and not using an electric water pump or fuel pump and the like, and your only power draw is the ignition. On a street car though, by the time you add up running a hot stereo, headlights, ignition, A/C and all of that you may actually be seeing very poor voltage going toward recharging the battery.
If I was to set up a car, I would run it to the battery regardless. Oh, one thing that doesn't come up often in this discussion, on some toyota units the dummy light wire also serves as the trigger wire. Mine would not charge at all until I wired it in.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Thumperdart]
#1372836
01/22/13 12:33 PM
01/22/13 12:33 PM
MR_P_BODY
Myself I wouldnt put the sense wire right on the alt... it would sense the voltage at the alt and not the battery and drive the alt voltage down.. that sure wouldnt be the same as the battery... it will not take into account of any line drop... I picked up my point from a continuous duty solenoid so its seeing one of the lowest voltages in the car and the battery is seeing 14.9 volt
