Re: Doing It Right The First Time
[Re: Sb Valiant]
#1372777
01/21/13 01:54 PM
01/21/13 01:54 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
The thing that gets me is yes I would like an engine to turn less rpm and be easier on parts but I don't want the engine to be a 10.0 engine because the car itself won't make it there the way it is now. It might be good for 10.40-10.50's and that's if we get everything we have now set right. Anything past this I can't see happening without getting a way better suspension then what we got!
Dont be sure about that. I have a buddy that has a 72 Duster, stock front suspension and super stock springs on the rear, nothing special, that has gone low 10.20's. His car weighs 3200 and he has a 408.
[Re: Sb Valiant]
#1372779
01/21/13 02:06 PM
01/21/13 02:06 PM
Triple Threat
Renton Washington
So you can either put less camshaft in it, short shift, pull timing, limit throttle or do many other things. Its really easy to slow a car down if you need to.
Heres what I would do if I was you;
408-416" 10:1 compression Scat rotating assembly Camshaft around [Email]250@.050[/Email] 550 lift Your W2's cleaned up with springs to match the cam Your intake 750 carb is plenty a GOOD 8" converter ~5000 stall
Gear/ tire it so you cross the stripe just a touch higher than where you shift.
That combo will go high 10's at 2800# with EASE, and live for years. It will also run on pump gas which will save you money and allow you to race more often. You don't need 12:1 compression and you don't need or want to turn 7000+ if you don't have to.
That's my opinion, I'm a 26 year old kid who has been racing since I got my license. I have raced on a tight budget and have been in your shoes before. I'm a bracket racer and put 200-300 runs a year on my car, so I've learned what it takes to get the job done.
