Page 1 of 3 1 2 3
Doing It Right The First Time #1372734
01/20/13 03:31 PM
01/20/13 03:31 PM
western PA
Sb Valiant Offline OP
western PA
I only want to buy a set of roller rockers once! I need a set that has a warranty if something breaks. For drag racing use only and rpms under 7500. Rockers that are needed are for W-2 Econo heads.
Re: Doing It Right The First Time [Re: Sb Valiant] #1372735
01/20/13 03:51 PM
01/20/13 03:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Warranty and racing dont go in the same sentence...
you want the best you can afford... I used the old
MP rockers(Crane made them).. they have a roller tip
but the shaft area was no bushing and rode on the shaft
and they worked well for years... now days all I use
is TD rockers... pricey but they work great.. this
pic is the set for a W-2 econo head
Re: Doing It Right The First Time [Re: MR_P_BODY] #1372736
01/20/13 04:16 PM
01/20/13 04:16 PM
western PA
western PA
I know some people that run very fast that run T&D rockers and say they are the best. I think harland sharps are ok and varly reasonable but they do tend to have there problems. I guess Norris rockers are post to be real nice pieces. Crane golds are post to be ok but some say stay far away from them.. So looks like between T&D or Norris is the best I am guessing?
Re: Doing It Right The First Time [Re: Sb Valiant] #1372737
01/20/13 04:21 PM
01/20/13 04:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its a matter of what the wallet says... the rest of
your engine is far from being maxed out but if you
can afford the best then buy then buy the best
Re: Doing It Right The First Time [Re: MR_P_BODY] #1372738
01/20/13 06:09 PM
01/20/13 06:09 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
I use TDs on my w-2s and spin to 8500. Never a problem after 3 years (n and I bought them used).
I used to break Harland Sharps once or twice a season
Re: Doing It Right The First Time [Re: mloboda] #1372739
01/20/13 06:30 PM
01/20/13 06:30 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
What rockers are on your heads now? Post up a picture of your heads, I'm pretty sure I saw that they are Race W2s from a pic I saw you posted previously.
Re: Doing It Right The First Time [Re: 340_Dart] #1372740
01/20/13 06:43 PM
01/20/13 06:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I must be missing something here. I thought the kid was on a tight budget and now he's talking $1200 rockers
Re: Doing It Right The First Time [Re: Quicktree] #1372741
01/20/13 06:53 PM
01/20/13 06:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I thought so also but I'm not asking that... he asked
a question.. I will answer to the best of my ability
thats all... then its his choice
Re: Doing It Right The First Time [Re: 340_Dart] #1372742
01/20/13 07:00 PM
01/20/13 07:00 PM
western PA
western PA
Here is a few pics of the rockers we have now when they were on the car.
Re: Doing It Right The First Time [Re: Sb Valiant] #1372743
01/20/13 07:01 PM
01/20/13 07:01 PM
western PA
western PA
Another
Re: Doing It Right The First Time [Re: Sb Valiant] #1372744
01/20/13 07:02 PM
01/20/13 07:02 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Whats wrong with them ?
Re: Doing It Right The First Time [Re: Quicktree] #1372745
01/20/13 07:03 PM
01/20/13 07:03 PM
western PA
western PA
All the more I'll go is hs rockers if I do decide to run rollers and if I have the money!
Re: Doing It Right The First Time [Re: VernMotor] #1372746
01/20/13 07:05 PM
01/20/13 07:05 PM
western PA
western PA
bad geometry and very ancient. Also not post to run these type of rockers with anything over 550 lift cam. I don't have any other pictures but I can get one since they are off the car and the adjusters are bad.
Re: Doing It Right The First Time [Re: Sb Valiant] #1372747
01/20/13 07:43 PM
01/20/13 07:43 PM
western PA
western PA
Maybe someone knows how to make these type of rockers work under a small block stroker and a 557 or 590 lift purple shaft cam. Rpm range around 6800-7200. Hp maybe like 450 hp.
Re: Doing It Right The First Time [Re: Sb Valiant] #1372748
01/20/13 07:49 PM
01/20/13 07:49 PM
Econo W2 and a stroker, yor really going to have to mess that combination up to have it only make 450 HP using a Mopar cam is a good start to acheive that goal
Re: Doing It Right The First Time [Re: Sb Valiant] #1372749
01/20/13 08:08 PM
01/20/13 08:08 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Your looking to run in the 10's right???
2800 lbs
340
econo W2's
Compression ratio???
With all I have read about your parts the .557 is a very good choice for you....
Check your springs and make sure you are not killing the seat pressure...... aim for 130 to 140 lbs
One thing you may be overlooking is your converter.... have you confirmed you have a good 8" in there........... if not this is where to spend your money.......
Re: Doing It Right The First Time [Re: Cab_Burge] #1372750
01/20/13 08:22 PM
01/20/13 08:22 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Cab, Brock lives app one hour from me and I TRIED to point him in a direction that he could build a low maintenance engine on a budget that would run 10's. Pump gas, 6400-6500 rpm, 520-550 lift solid cam, his W2 heads and a good intake (I like the W2 Victor). Hopefully his chassis works well enough and a 5200-5500 convertor. In his 2800# car that combo should go 10.20's-10.50's
I had to edit this to add that I also recommended using a H beem connecting rod instead of wasting money reconditioning stock rods.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Doing It Right The First Time [Re: pittsburghracer] #1372751
01/20/13 08:36 PM
01/20/13 08:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
From what I hear he has a few people TRYING to help
him out but some are saying they are talking to deaf
ears... I dont know but I sure hope he listens to
a few of them... that should help him and save him
time and money
Re: Doing It Right The First Time [Re: pittsburghracer] #1372752
01/20/13 08:38 PM
01/20/13 08:38 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
If he changes rods will he not need a re-balance??? Good rod bolts and a re-size will work at that RPM.........
What pistons?? how heavy are they??
Re: Doing It Right The First Time [Re: pittsburghracer] #1372753
01/20/13 08:43 PM
01/20/13 08:43 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I ran a .550/.557 Lunati cam in my first 360 and ran Harlan Sharps and never had a problem with them, and know several others that have run them for years also with out failures.
Page 1 of 3 1 2 3
