I posted this in the resto section, perhaps the wrong place. I'm trying to identify which valve is the correct one for 71 pwr disc floating caliper / drum Satellite.
According the FSM I need both a proportioning valve which also connects to a metering valve supplying the ft brakes but it also says " if used" in the diagram regarding the metering valve. I assume I need both the prop. & meter valves to function properly. It does show the Fixed Caliper Disc as not using a metering valve, whats the reason for that?
Since the diagram says " Barracuda" can an I assume an e-body valve setup is identical to a B body?
heres a scan from the FSM...
Can I also assume the flat machined brass style prop & meter valves are the kind I should chase?
I'm looking to acquire one not replace an existing one as I never had one to start with. Just trying to ID the proper one before I buy.
Anyone know which part is the correct aftermarket ones, there's seemingly tons of them.
Thx!
