Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372235
01/21/13 08:56 PM
01/21/13 08:56 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
If I ever get mine together it will be old school. Breathers new in the box for 57.00 each.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: 67HEMI] #1372236
01/21/13 09:44 PM
01/21/13 09:44 PM
Great Neck,LI,new york
hemi-itis Offline OP
I have a set of "old school" covers.I knew I wanted polished fabbed aluminum covers the 1st time I saw a set
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372237
01/21/13 10:32 PM
01/21/13 10:32 PM
X
xram426 Offline
xram426  Offline
X
I fixed mine like this . Reason for this modification was that cutting off the top of a Afco adjustable shock was not a option. The bolt hole was also moved 7/8" out towards the fender. These Moroso covers are for sale $300 plus shipping.
Mark 831 277 4931
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: DusterDave] #1372238
01/21/13 10:50 PM
01/21/13 10:50 PM
Top unscrews to add oil.
And, they include a tire sidewall scouring pad. Nice!!!
Hemi-itis, you can see here where I put my burndown breathers. Never picked up oil in those locations.
Dave,do those style breathers have a baffle?Where do the breather hoses go,puke tank??
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: pattyboy 572] #1372239
01/21/13 10:53 PM
01/21/13 10:53 PM
AL, can u cut the shock bolt ....had to do it for my fender well headers on my 68rr....pat
Pat,how did you hold the shock stud once you cut it?Vise grip from the fenderwell side?
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372240
01/21/13 11:14 PM
01/21/13 11:14 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
AL u got it ...broken ds motor mount and the shock stud went through header... cut it flush to the nut....see if will clear it prior to cutting.....pat
