aluminum heads #1372041
01/19/13 01:23 AM
01/19/13 01:23 AM
florida dade
cesar perez Offline OP
florida dade
what is the best flowing bb heads that are not raised port design and what matching tunnelram the application is street car
Re: aluminum heads [Re: cesar perez] #1372042
01/19/13 01:36 AM
01/19/13 01:36 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I don't have numbers to back these suggestions, but I gotta believe the Indy EZ heads flow about as well as any standard port window designs. If you really want a tunnel ram, I've read in the past that the Weiand Hi-Ram is a pretty good piece equimpment, with the M1 tunnel ram being right there.
Re: aluminum heads [Re: cesar perez] #1372043
01/19/13 04:29 PM
01/19/13 04:29 PM
Idaho
LaRoy Engines Offline
Idaho
OOTB flows from the same flowbench for the (1) early Stealth, (2) late Stealth, (3) RPM, (4) Indy EZ
............(1)...........(2)..........(3)...........(4)
.100........66............73...........74............66
.200.......142...........141.........148..........127
.300.......209...........214.........209..........181
.400.......240...........245.........254..........232
.500.......255...........262.........276..........272
.600.......267...........276.........287..........299
.700.......268...........281.........291..........315
Even with the Indy's larger 2.19" intake valve vs the others 2.14" valve, there is no OOTB advantage to the Indy EZ until you get over .500" lift. In fact, if you look, they even don't flow as good up to .400" lift.
Keep in mind that the Stealth and the Edelbrock RPM can be hand ported to 340+ cfm and the EZ can be ported to 360+ cfm. In order to do so, it is generally required to open the ports to Max Wedge height.
Mid 330 cfm flows can be had, from the RPM and Stealth, with a stock intake port window.
Re: aluminum heads [Re: LaRoy Engines] #1372044
01/19/13 05:41 PM
01/19/13 05:41 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
heyoldguy late stealths ? thanx charlie
Re: aluminum heads [Re: CSK] #1372045
01/19/13 06:22 PM
01/19/13 06:22 PM
New York
1stBxMopar Offline
1stBxMopar  Offline
New York
I prefer the Indy EZ, I have run the standard port window with a tunnel ram and also max wedge port window with a single dominator. The heads were hand ported in both applications and got great flow numbers.
Re: aluminum heads [Re: 1stBxMopar] #1372046
01/19/13 06:25 PM
01/19/13 06:25 PM
New York
1stBxMopar Offline
1stBxMopar  Offline
New York
Another of the tunnel ram with standard port window
Re: aluminum heads [Re: CSK] #1372047
01/19/13 09:42 PM
01/19/13 09:42 PM
Idaho
Idaho
Coupla years ago when I was buying Stealths, they were not hand blending the seats into the aluminum bowls like the last four sets I have received. On the later Stealths it appears they are trying to emulate the blending that Edelbrock has been doing on the RPM heads.
Re: aluminum heads [Re: LaRoy Engines] #1372048
01/19/13 10:29 PM
01/19/13 10:29 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
intresting info...thanks for sharing.
