Re: TAKING IT TO THE "NEW" NEXT LEVEL!!
[Re: Troy]
#137162
10/16/08 07:18 PM
10/16/08 07:18 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Dave, (by the way I hope all is well) Who are you restoring the car for??? For yourself?....The people in the hobby? Or for the people that just want to sture the pot?? This might be a question that you need to answer.
Hello Troy! Always good to hear from you. The question was really rhetorical in nature. When you do things like this, the motivation has to burn from within. Again I wanted to make clear that this will not be a casual clean and wax job. It will actually be MORE involved than the last two cars. I will be documenting aspects that were never even considered with the other cars. For instance, when I remove the tie rods from their sleeves I will count the threads that are protruding from the lock nuts that hold the clamp in place. Why? For a couple of reasons. Number one, I will put them back exactly the way they came off. Same amount of threads showing after the nut. The clocked position of the nuts will also be duplicated when reassembled. Second, it will be interesting to see if the torque specs are in line with how tight the factory originally tightened them. I realize that specifications change once a part has been stressed but it will still be interesting to see how close they were to the published specification. A lot of people talk about how these cars were built in a haphazard fashion, so it will be educational to witness the outcome of some of the findings. I have many other areas that I hope to find facts on regarding how these cars were actually built. I wonder how many other people check torque specs on their cars when they wash, wax and clean the windows?
[Re: badblack68]
#137164
10/16/08 07:25 PM
10/16/08 07:25 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
They are only as assembled by the factory once.
We can hopefully change that line of thinking!
[Re: ECS]
#137165
10/16/08 07:30 PM
10/16/08 07:30 PM
Posts: 21,835 Kirkland, Washington
Pacnorthcuda
How are you going to differentiate from "breakaway torque" (what I assume you are measuring when you remove a fastener) and "installed torque" (which is what the factory tightened the fastener too)???? They are most certainly two different values!
Or are you measureing the torque required to return the nut/bolt to its clocked position and recording that value as installed torque? In the case of gaskets, that most certainly would change.
[Re: Pacnorthcuda]
#137166
10/16/08 07:40 PM
10/16/08 07:40 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
We will not be calculating the breakaway torque. The torque will be calculated after the parts are void of ALL oxidation and then reassembled. The thread count and nut configuration will be compared to the "before" documentation. That is why I mentioned the pre-stress condition that occurs on parts when they are originally assembled.
[Re: ECS]
#137167
10/17/08 01:15 AM
10/17/08 01:15 AM
Posts: 503 Sooner state
Slim Smitty
Sooner state
Let the party begin. I'll be following this one all the way. I loved the last project and look forward to all the details of this one. I also like the bickering this one's all ready stirring up. I get a kick out of it. Kinda like watching a reality tv show. The fender tag and vin tag topics on this site are a hoot too!
65 Coronet
[Re: Iceman01]
#137171
10/17/08 03:08 PM
10/17/08 03:08 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Thanks (to the last 3 individuals who posted) so much for the encouragement concerning this project. I will be documenting and providing a step by step analysis for anyone who is interested about the steps that will be taking throughout the entire process. We will be documenting the mil thickness of paint on every square foot of each body panel. It will be interesting to see the variance of paint that was applied during the factory painting procedures. The first thing we will do will be to get the car on a lift and have every inch documented with digital pictures. Jon (who does our graphics) will position a camera under the car, while it is suspended and take pictures spaced six inches apart. It will take over 100 pictures that will then be put together in photo shop to provide a seamless view of the complete underside of the vehicle. We will also take separate close up photos of all the various components under the car. A narrated video documenting the same details will also be used to reference the original components. That should accurately cover every detail/part that will need to be reinstalled when finished at a later date. Take a look at the underside of the Challenger that Jon put together in photo shop. It was done with about 50 pictures that was fused together using computer programs. To complete this photo the camera was spaced about 12 inches apart. Using a six inch picture format for the A Body project should provide a much better view of documentation for the components.
[Re: ECS]
#137172
10/17/08 03:56 PM
10/17/08 03:56 PM
Posts: 6,717 KY
65pacecar
KY
Dave,
This sounds like an excellent project and will serve as a guide for not only future restorations and new product development but also in verifying, maintaining and proper handling and care of Survivor cars. I have been planning a very similar endeavor in the future with one of my cars. I am currently finishing the restoration on a 65 Sport Fury Hardtop and will be following it with either a 340 Cuda or Demon for my wife. The project I have been planning is similar to your idea and I will be performing this task on my 65 Sport Fury Convertible Indy Pace Car. I have had this car since I was 16, bought it from the original owner, an elderly gentleman in his late 70’s (also named Shannon); that kept the car in a heated garage since new and took pristine care of it. The Sport Fury still retains its original paint (Excellent condition), Interior which is near perfect, the top still looks new, but the rear window is clouded and is one item that will be replaced, the original suspension still feels tight etc. The Plymouth was so nice, that even as a 16 Year Old I bought a 76 Volare to beat on to save my car and keep it in nice condition. The car shows minimal wear but has accumulated some dirt and grime in areas that cannot be cleaned properly without disassembly; for years I have considered a ground up restoration, but over the past year I have decided to do a project very similar to yours since I don’t want to kill its character. I plan to dismantle the car, document as I go (You have already given me some excellent ideas on the amount of detail and documentation I need to achieve), restore all of the original components as much as possible and replace (in my case at least) only the items that have to be replaced. I have restored two 65 Sport Fury’s already and am currently finishing a black hardtop that has helped develop a process that I prefer and acquire knowledge of the assembly line techniques and patterns on these cars; I have taken extensive notes along the way. I have also accumulated a number of NOS and NOS Assembly line parts for these cars since the late 80’s and even though the other Sport Fury’s were total restorations to correct specs, I have always held back the best of the best for this car in anticipation of a complete restoration. Since deciding on preserving the original fit, finish and as many of the components of the car as possible; most of the NOS parts will probably end up staying in inventory, but that is fine. I am looking forward to your documentation and revival of this car; I know it will serve my project and others well by illustrating both assembly line technique and patterns along with the craftsmanship it takes to accomplish a project such as this.
Best of luck to you and your team with this project, it will take a lot to rival the Challengers accomplishments if it’s even possible, I look forward to seeing the finished product and the updates along the way.
Shannon
[Re: ECS]
#137173
10/17/08 04:39 PM
10/17/08 04:39 PM
Posts: 1,660 Cleveland, OH
TWS
Cleveland, OH
Now THAT gets my vote for Mopar photo of the year. Spectacular photography and photoshopping! You could sell posters of that. If only there was a way to shoot the parts of the car above the ramps and the tire bottoms.
[Re: ECS]
#137175
10/17/08 05:14 PM
10/17/08 05:14 PM
Faxon is working on the factory assembly line manuals for a-bodies. Will one of these manuals be used on this project. I have put everything on hold for my Dart until I can obtain a copy.
[Re: I go fast]
#137180
10/17/08 06:27 PM
10/17/08 06:27 PM
Posts: 920 Grafton, OH
lmn6pack
super street
super street
Grafton, OH
Dave, I guess you answered my question in the last thread "taking it to the next level". The question being what have you learned from the challenger and can you "create" an even better masterpiece. Good luck with your endeavor! Rick Janosik
[Re: lmn6pack]
#137181
10/17/08 07:52 PM
10/17/08 07:52 PM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
Dave,
Rick Janosik
No,and if I did it wouldn't be 3500ls's of steel with four wheels.Also,my head is still not to big for my hat to fit.
