Nice stroker 383 on the dyno today #1371681
01/18/13 05:13 AM
01/18/13 05:13 AM
SoCal
Brian Hafliger Offline OP
SoCal
Going in a 69 RR, daily driver on pump gas.
4.250 Source stroker kit, 10:1, ported stealth heads, rpm intake, 850DP, TTI headers, custom IMM hyd. roller cam, PRW stainless 1.6 rockers.
dyno video: http://youtu.be/N9kiYW5khYc
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371682
01/18/13 05:14 AM
01/18/13 05:14 AM
SoCal
SoCal
Sleeper look:
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371683
01/18/13 05:15 AM
01/18/13 05:15 AM
SoCal
SoCal
Dyno pg.1
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371684
01/18/13 05:15 AM
01/18/13 05:15 AM
SoCal
SoCal
Dyno pg.2
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371685
01/18/13 05:16 AM
01/18/13 05:16 AM
SoCal
SoCal
Dyno pg.3
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371686
01/18/13 05:17 AM
01/18/13 05:17 AM
SoCal
SoCal
Graph
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371687
01/18/13 08:31 AM
01/18/13 08:31 AM
tboomer Offline
tboomer  Offline
Nice,Brian! Gonna be a happy customer when he hits the go pedal!
Re: Nice stroker 383 on the dyno today [Re: tboomer] #1371688
01/18/13 09:03 AM
01/18/13 09:03 AM
The Great White North
RAMM Offline
RAMM  Offline
Tight LSA on the cam? Looks like your C.F. was just about 1 to 1 that day-nice weather. Today its - 14.8 F my C.F. would correct down not up! Nice engine that is a ton of torque. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371689
01/18/13 11:49 AM
01/18/13 11:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Nice sounding engine , what do the heads flow ?
Re: Nice stroker 383 on the dyno today [Re: JohnRR] #1371690
01/18/13 11:51 AM
01/18/13 11:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
good numbers...
Coming soon!!!!
Re: Nice stroker 383 on the dyno today [Re: RAMM] #1371691
01/18/13 01:16 PM
01/18/13 01:16 PM
SoCal
SoCal
The TQ curve looks wild, but if you plot it out over a wider span it would look different. If you notice, it looks like it really drops fast, but it's not too bad for a mild port.
Yes it's been good weather lately!!
The heads flowed 270 at .400 and 292 at .500.
Brian Hafliger
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371692
01/18/13 01:26 PM
01/18/13 01:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Very nice with good #'s. Is that the RPM intake ? The Indy dual plane I use kinda looks like an RPM intake on steroids. Its not far from my combo but I use a 4.15 crank in a .030 over 440 block for 493 cubes. I use an 850 DP and run on pump also. I have EZ heads and 10.6 comp and I use a solid flat tappet cam. That should run pretty good in your Roadrunner. I guess I make about 600 hp in my 493 so far to run 10.70's at 3700 lbs. You should run easy 11's and maybe very low 11's. Good luck , Ron
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371693
01/18/13 02:41 PM
01/18/13 02:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Brian dont you think it was a bit fat on the top end...
looks like it was progressively getting fatter....
that has some nice torque for sure.. what was the CI
on that
Re: Nice stroker 383 on the dyno today [Re: MR_P_BODY] #1371694
01/18/13 02:50 PM
01/18/13 02:50 PM
SoCal
SoCal
That wasn't the last pull. We ended up jetting it down some, got the AF's in the high 12's and low 13's. Gave up just bit of power, 555HP and 605TQ but averages were same so no big deal.
CID is 496. The stealth heads needed alot more port work but price was king on this deal and this is what the customer wanted (550HP and 600TQ).
It's a real driver, no track time plus running power brakes, steering and A/C so we had to keep it civil. But not bad for 14" of vacuum right at 850rpm. It idled down to 750rpm, but didn't sound happy so 850 was much better.
Brian
Brian Hafliger
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371695
01/18/13 03:40 PM
01/18/13 03:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Real nice set up... he'll be a very happy camper
Re: Nice stroker 383 on the dyno today [Re: MR_P_BODY] #1371696
01/18/13 07:21 PM
01/18/13 07:21 PM
Amherst,NY
challengermike Offline
Amherst,NY
Keep an eye on the rockers lock nut. I had to replace mine with harland shrap nuts to keep them from backing off. Other than that i like the rockers. It took about 600 miles for them to start backing off.
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371697
01/18/13 07:32 PM
01/18/13 07:32 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Real nice build Brian ! Can you tell us about your cam choice or does it need to stay under wraps for now? I love the stealth looks!
Keith
Re: Nice stroker 383 on the dyno today [Re: Dunnuck Racing] #1371698
01/18/13 07:51 PM
01/18/13 07:51 PM
SoCal
SoCal
Keith
So far no problems with the nuts backing off...I've used about 25 sets of these things so far, but thank you for the heads up!
Cam is 244@ .040, .580 lift on a 113lca in 2.5° advanced.
Brian Hafliger
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371699
01/18/13 08:32 PM
01/18/13 08:32 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Awesome job, Brian!
How do the PRW's compare to the Comps? Are they an exact copy?
Love to see a side by side with a 440-2D on that....484 is it?
WIZE
In Car:
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371700
01/18/13 08:39 PM
01/18/13 08:39 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
NICE!! I'd like to have a engine like that one.
Nautilus Racing-
