Repainting headers to last #1371644
01/18/13 12:39 AM
01/18/13 12:39 AM
Harrisburg Pa. 17112
moparmikethree Offline OP
I have to remove the headers on my car, and the paint is flaking off.How do I repaint them so it lasts alot longer. I don't have money to ceramic coat them. Can headers be power coated? or use high temp
paint. should they be primered first
Re: Repainting headers to last [Re: moparmikethree] #1371645
01/18/13 01:54 AM
01/18/13 01:54 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Finding a cure for cancer would be easier.
Re: Repainting headers to last [Re: Stanton] #1371646
01/18/13 08:03 AM
01/18/13 08:03 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Headers on my 70 Buick 455 have been in place for 17 years !!!! I wouldn't believe it either if someone told me that, but it is true. I have taken them off a couple times during that time though, here's what I do.
Sandblast thoroughly, be sure you get around all welds.
Hang and blow off then wipe entire header with laquer thinner to remove any residue, do not touch the outside surface with your hands.
Paint with "VHT" brand header paint.
Use care when installing to not scratch the paint off.
That's it, granted the car sits inside and is only driven on weekends, etc, but that in itself can be more detremental than driving often, which keeps them dried out inside.
These are not ceramic coated or powder coated, just done as I described above and they have been on the car since 1996 (knock on wood!).
Jess
Yeah, it's hopped up to over 160...
Re: Repainting headers to last [Re: jt4406] #1371647
01/18/13 09:30 AM
01/18/13 09:30 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Jess
I've had great luck with VHT's 1200 degree paint using these techniques too. Plus, it touches up real nice as well.
Re: Repainting headers to last [Re: jt4406] #1371648
01/18/13 11:33 AM
01/18/13 11:33 AM
Put it in a large thin garbage bag before installing it. EDIT someone mentioned something in a prior post about using a torch to burn the oil residue off of it then a thorough lacquer thinner cleaning I would assume.
Re: Repainting headers to last [Re: RapidRobert] #1371649
01/18/13 11:40 AM
01/18/13 11:40 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I've been using Krylon stove & bbq paint for years with really good results.
http://www.sears.com/shc/s/p_10153_12605...=30-107334392-2
Re: Repainting headers to last [Re: moparmikethree] #1371650
01/18/13 11:42 AM
01/18/13 11:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Take them down to metal, wipe them clean w/ brake clean, spray them w/ VHT header paint... or BBQ paint. Both work well.
Coming soon!!!!
Re: Repainting headers to last [Re: Mr.Yuck] #1371651
01/18/13 08:50 PM
01/18/13 08:50 PM
thank you every one, good tips
Re: Repainting headers to last [Re: moparmikethree] #1371652
01/19/13 11:11 PM
01/19/13 11:11 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Check out Tech Line Coatings. I've used a product called BHK which is a satin black coating for headers. Holds up good for me. http://techlinecoatingswebstore.com/
Re: Repainting headers to last [Re: moparmikethree] #1371653
01/20/13 12:18 AM
01/20/13 12:18 AM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
When I did the headers on the 68 I used a propane torch(a weed burner will work also) to preheat the cleaned/blasted headers prior to painting with white VHT 1200,then used several 5 minute heat up runs after they were re-installed to finish curing the coating. They still look good been on the car for at least 15 years(not my daily driver any more),D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
