Shift or not #1371415
01/17/13 09:37 PM
01/17/13 09:37 PM
nc
E
emarine01 Offline OP
E
nc
Ok as most of you know this is a 200ft mud track question so bear with it and apply what you know to the circumstances, I run lo range with a 727 & a 5k stall that flashes @ 5400 , We shift twice and in 3rd @ the traps we have 85 MPH wheel speed @ 7k, If I run Hi range in first gear @ 7k I have 85 MPH, Which do you think will ET faster? Shift twice in Lo or no shifting in Hi 1st gear?
Re: Shift or not [Re: emarine01] #1371416
01/18/13 06:31 PM
01/18/13 06:31 PM
Guitar Jones Offline
Don't know. Lots of variables being a mud truck and all. Why don't you just try it?
Re: Shift or not [Re: Guitar Jones] #1371417
01/18/13 08:39 PM
01/18/13 08:39 PM
nc
E
E
nc
Good point Jones ... .... But then I'll have to wait for spring
Re: Shift or not [Re: Guitar Jones] #1371418
01/18/13 10:37 PM
01/18/13 10:37 PM
Re: Shift or not [Re: Cab_Burge] #1371419
01/20/13 10:27 PM
01/20/13 10:27 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
Why not just start in 3rd gear, low range? That way the trans is in 1:1 and your gear reduction is clear back in the transfer case.
Wheather I'm 4 wheeling, mud racing, or truck pulling I run low range. It moves the torque further back in the drive line. You will likely not hurt anything with the gas engine, but a buddy used to run a hot cummins with a 727 in an offroad truck. Whenever he used high range, he would either break the output shaft of the trans or the input to the transfer case.
Whenever a Chevy with a 4speed that runs very good tries to pull high range, 1st gear(its slightly faster then low range 2nd), they almost always will brake the coupler between the trans and t-case. If they hook in low range and pull in 2nd, they get to make many passes with no breakage.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: Shift or not [Re: MMiller] #1371420
01/21/13 02:57 AM
01/21/13 02:57 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
Michael
Also less chance of damaging the sprag than if it was in first.
