Re: TAKING IT TO THE "NEW" NEXT LEVEL!!
[Re: A12]
#137522
05/11/09 06:58 PM
05/11/09 06:58 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
So are there deductions for non-correctness on reproduction parts
You get ZERO points in OE judging, for having a repo part. All “parts” are capable of receiving two point’s total. One point for originality and one point for the condition of the part. Since a repo is not original, it is automatically given a full one point deduction in that area. When you think about it, that is 50% of the total amount possible for any particular component. The part basically receives a failing grade before it is judged!
[Re: sam c]
#137526
05/12/09 10:52 AM
05/12/09 10:52 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Hi Dave,I am currently getting ready to send my bumpers out for rechroming.I heard that you have obtained nos for the valiant.Could you post some pixs of the bumpers?I have been told that there are imperfections in original bumpers that are not duplicated after rechroming Thanks in advance.
Hello Sam! We did find all the "chrome" for this car in original NOS condition. You are correct about the finish. The originals appear to have a bit of an unfinished (scratched?) metal surface UNDER the chrome. I took some pictures of the rear bumper and one of the reverse lights we were able to locate. Dave Stuart has been responsible for finding about 75% of these parts. He is the Midwest District Zone Manager for Chrysler and has been able to locate original items from his data base that is linked with EVERY Chrysler outlet across the Country. (He has by far been the main catalyst to our project. We have even found all the original "paper" gaskets that a few were inquiring about earlier in this thread.) The "chrome" parts we have found are in beautiful condition! No scuffs or scratches whatsoever. No reproduction parts!!!
[Re: ECS]
#137527
05/12/09 12:31 PM
05/12/09 12:31 PM
Posts: 2,309 South, FL
cudaized
South, FL
...Here are a few photos of the battery.
Hi Dave, Thanks for the pictures of an assembly line battery. Perhaps you will be providing a repro service for the "correct" battery in our future?
Ola Nilsson
[Re: cudaized]
#137528
05/13/09 02:34 PM
05/13/09 02:34 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Here was an interesting bit of "detail" information that was a surprise for us. How many people knew that the doors on these vehicles were primed on the back sides of the door skins BEFORE they were mated to the inner door frame structure? After the car body panels were assembled, the car was then dipped/submerged by the conveyor primer line. The first layer you will see on the back side of the door skin is the light color primer followed by the darker dip color.
[Re: ECS]
#137529
05/13/09 03:19 PM
05/13/09 03:19 PM
Posts: 1,101 Ont, Canada
moparo
Ont, Canada
Hi Dave They also put the panel treatment (undercoat?) on before the skin was mounted. Same for the quarter panels
performancecarrestorations.com
[Re: moparo]
#137530
05/13/09 07:38 PM
05/13/09 07:38 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Hi Mauro, The panel treatment you mentioned is referred to as a Mastic sealer. It was also sprayed on prior to the door skin being mated to the door frame. That particular layer was not used for "corrosive" purposes but as a sound deadened. If that material was not applied to the large metal door skins they would have sounded like a bass drum when they were closed. The same for the quarter panels. Had the Mastic material had not been applied to that area, rocks or any other exterior "knock" would have resonated throughout the enclosed (void) areas. The black color is over spray that blew through the door openings while it was being painted at the factory.
[Re: ECS]
#137531
05/13/09 07:58 PM
05/13/09 07:58 PM
Posts: 243 St. Louis, MO
DodgeMaterial
St. Louis, MO
Dave -you are correct. One nice thing about working on such a well preserved and original car is the ability to learn and share with everyone. I confirmed our findings with Mr. Mike Masich. Mike worked in Chrysler stamping during the late 60s and early 70s. He described after stamping a door skin (or quarter panel) they would spray prime and then apply "dumb-dumb" (mastic sound deadener)on the inside, then final assemble the door shell and ship to the assembly plant or parts depot. With this car being so clean you can easily see all of the stages including the overspray in the doors of the assembly plant paints... both blue (interior color) and black (exterior color) are evident and even allow you to vision the strokes of the painter. Hope this helps - Dave S.
DodgeMaterial - Dave
JS29U0B - FK5 - 440-4 Auto
WS23V0A - EB5 - 440-6 Auto
[Re: DodgeMaterial]
#137532
05/13/09 11:52 PM
05/13/09 11:52 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
How will you remove all the rust or surface oxidization on the inside of the upper half of the inner door structure as shown in the above picture? I'm sure it wasn't there when the car was new....and you know we'll want before and after pictures once you're finished
CHECK OUT MY NEW WEB SITE !
[Re: anlauto]
#137533
05/14/09 12:53 AM
05/14/09 12:53 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
With rust remover!!?!!?! Was this a trick question Alan? After spending over an hour to remove oxidation from a screw that was half way under the VIN tag, did you think THIS would really be an issue? When those parts are finished, you will NEVER know they had ANY trace of oxidation whatsoever. (If you like I will send you a complimentary framed copy of the “before” and “after” photos.)
[Re: anlauto]
#137534
05/14/09 01:10 AM
05/14/09 01:10 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Hi Alan, Help me out with this one! I literally just received an email from someone reminding me of a previous post (about the Cuda in 2005) where someone claimed, THAT particular car did not represent a factory delivered vehicle because there would have been “flash” rust on the bare metal resulting from the water test. I certainly can’t offer both types of “finishes” so what should do I do? Do I take the rust off and have one side argue that it SHOULD be there, or leave it as is and have the other side argue that it SHOULD NOT be there? The other option would be to remove only half of it and be correct on both counts!
[Re: ECS]
#137535
05/14/09 07:06 AM
05/14/09 07:06 AM
anlauto
Ohhhh......so who has the trick questions now....eh??? The answer is quite obivious....and we here at MOPARTS wouldn't expect anything less..... You need to spend countless hours removing any sign of rust inside the doors, under the dash, rear parcel shelf, etc... Then without question you need to construct a water test facility to re-create the water test done to this car in 1970.... ....then whatever flash rusts in the time it takes you to get this car to the judging block..... be sure to transport it on an open trailer, ...should mimic closely the amount of flash rust that would have been on the car on the dealer's lot. I'm surprized you had to ask.... P.S. A framed before/after picture will not be neccessary, but thatnks...
[Re: anlauto]
#137536
05/14/09 12:00 PM
05/14/09 12:00 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
You just made this too easy! At this point I could say that we DID remove the flash rust and everything you see in the pictures WAS the results of our simulated “water test.” Isn’t that the type of response that prompts the suspicious, rhetoric questions regarding many of the things we are doing or the parts we find? (I especially love the poorly camouflaged “test” questions.)
Don't worry Alan, shortcuts, embellishments or compromised truths will never be a part of the equation. People can safely perceive this project for what it represents. Those who consistently “question” under a suspicious or cynical view are simply exposing their own ilk or personal traits. What you see is what you get!
[Re: anlauto]
#137540
05/18/09 05:42 PM
05/18/09 05:42 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Great...Now we'll need "before", "after" and "DURING" pictures...
I experimented a little with the removal of the flash rust. I spent about 10 minuets on a small area to show the contrasting difference. (The wiper motor area in the picture was not included.) I should be able to remove all traces of flash rust with no abrasive materials and the metal will look pristine.
I also included a picture of the quarter side marker light area. There was a huge debate a year ago as to whether body components or accessories (with gaskets) were painted on or off the car. Would anyone care to guess how the quarter side marker lights were painted on this vehicle?
