Re: Master cylinder push rod seal.
[Re: 70dart318]
#1371044
01/17/13 11:10 AM
01/17/13 11:10 AM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
Your master cylinder has a spot for one right? PM me your address and I'll send you one.
[Re: MPerry]
#1371046
01/17/13 12:39 PM
01/17/13 12:39 PM
RapidRobert
At your parts house get a snip of vac hose the same length as the recess behind the rounded nub on the end of the pushrod. I forget the dia but just hand the guy the pushrod & have him cut a piece of a dia that is tight over the nub. The OE retainer piece is identical to a snip of hose except it has a groove along it's length which might be there just from the manufacturing process or put there deliberately to let air excape when you push it into the blind piston recess so it will seat all the way so I cut a shallow groove just to make sure. Look in the back of the M/C piston & if the recess is smooth tapered like the inside of a thimble then it is a power brake M/C & will not work in a manual brake app. If the inside has a wide machined groove around the circumference about halfway down (that's where the retainer hose snip seats) then that is a manual brake M/C & you're set (assuming the bore dia is what you need for your setup) though I used a 1&1/8" bore M/C in a manual brake app (74 A discs/10" drums) & the pedal was not excessive
[Re: RapidRobert]
#1371047
01/17/13 12:47 PM
01/17/13 12:47 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
This isn't always true. I just picked up a power master at O-reilly's that was a 15/16" bore that had a recess for the retainer. The manual one had a larger bore. The brand was Cardone.
http://www.oreillyauto.com/site/c/detail...2&ppt=C0066
[Re: mopowers]
#1371048
01/17/13 12:58 PM
01/17/13 12:58 PM
RapidRobert
Actually a manual brake M/C must have the machined groove for the retainer though a PB M/C may or may not have it as the snip of hose ain't used in a PB app therefore the recess is not used & if it (the recess) is there it serves no purpose other than the M/C can fit both apps assuming the bore dia is correct (or close enough)
