Reversed lo/high beam indicator light #137089
10/15/08 09:39 PM
10/15/08 09:39 PM
NJ
N
Nvr4Get911 Offline OP
N
NJ
'66 Barracuda
I noticed the other day that the Lo/High beam dash light is reading reversed. It lights red for lo beam and goes off for high beam. I haven't touched anything electrical on the car in years.
I replaced the switch w/ a new one and the same thing occurs. Wires look fine and the area is dry. Any insight fellas?
273 HYPO
Re: Reversed lo/high beam indicator light [Re: Nvr4Get911] #137090
10/15/08 09:48 PM
10/15/08 09:48 PM
Fort Lauderdale, FL
Suregrip Offline
Suregrip  Offline
Fort Lauderdale, FL
I would suspect that the wires to the dimmer switch were reversed...
Some people you just can't reach...
Re: Reversed lo/high beam indicator light [Re: Nvr4Get911] #137091
10/16/08 06:41 PM
10/16/08 06:41 PM
NJ
N
N
NJ
Don't see how...I never touched anything dealing with the headlights/switches since 2001 when I bought it. Is there a short somewhere?
Re: Reversed lo/high beam indicator light [Re: Nvr4Get911] #137092
10/16/08 09:17 PM
10/16/08 09:17 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Make sure your instrument panel is grounded good. Sometimes the power will "bleed" thru a bulb that shouldn't be burning trying to get to ground. Worth a try!
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
