What dimensions for pilot hole of 4-speed 440 crank? #1370847
01/16/13 10:38 PM
01/16/13 10:38 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I've got a used OEM forged 440 crank and it occurred to me that I have no idea whether it's compatible w/ a manual trans or not. What would the dimensions of the pilot hole be for a crank that would accept the standard bronze input shaft bushing? Thanks.
Re: What dimensions for pilot hole of 4-speed 440 crank? [Re: BradH] #1370848
01/17/13 12:30 AM
01/17/13 12:30 AM
SW Iowa
gearhead452 Offline
gearhead452  Offline
SW Iowa
2012 Hot Rod Drag Week, Street Race BB/NA, 4th Place.
Re: What dimensions for pilot hole of 4-speed 440 crank? [Re: gearhead452] #1370849
01/18/13 02:51 PM
01/18/13 02:51 PM
BradH Offline OP
BradH  Offline OP
How much of a press fit is required? And any idea how big the ID of the hole in the cranks that were NOT intended for manual transmissions was for comparison?
Re: What dimensions for pilot hole of 4-speed 440 crank? [Re: BradH] #1370850
02/16/14 07:58 PM
02/16/14 07:58 PM
BradH Offline OP
BradH  Offline OP
Still need to figure out if my OEM crank is 4-speed compatible or not as is...
Re: What dimensions for pilot hole of 4-speed 440 crank? [Re: BradH] #1370851
02/16/14 08:32 PM
02/16/14 08:32 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Why dont you look at it ?
I am truckless..
Re: What dimensions for pilot hole of 4-speed 440 crank? [Re: BradH] #1370852
02/16/14 09:50 PM
02/16/14 09:50 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Re: What dimensions for pilot hole of 4-speed 440 crank? [Re: moparfan53] #1370853
02/17/14 12:38 AM
02/17/14 12:38 AM
BradH Offline OP
BradH  Offline OP
Some info for you. The first thread has the pilot hole sizes.
https://board.moparts.org/ubbthreads/showflat.php?Number=5456989
And from that, the answer is: "If the crank is finish reamed for a bushing the bore will measure .9375". Cranks that are only pilot drilled but not finish reamed will measure about .8125"."
Re: What dimensions for pilot hole of 4-speed 440 crank? [Re: BradH] #1370854
02/17/14 12:55 AM
02/17/14 12:55 AM
dogdays Offline
dogdays  Offline
And the bearing that sits in the torque converter ring makes this question much less important. Usually there is some sort of hole drilled in the crank and the nose of the input shaft will fit inside. If it's not drilled, you shorten the input shaft with a cutoff wheel.
My '86 318 had such a hole and the input shaft fit in no problem, the engine was out of a Fifth Avenue which never had a manual transmission option.
R.
Re: What dimensions for pilot hole of 4-speed 440 crank? [Re: dogdays] #1370855
02/17/14 01:29 AM
02/17/14 01:29 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I went thru the same thing a few months ago, 73 440 had the hole deep enough but not finish reamed.
I used a mid 90s magnum 318 roller pilot bearing from napa.
Re: What dimensions for pilot hole of 4-speed 440 crank? [Re: Diplomat440] #1370856
02/17/14 03:39 PM
02/17/14 03:39 PM
dogdays Offline
dogdays  Offline
Winning!
R.
